Damaged Red R35 At Auction
repairable write-off
Someone correct me here, but I thought a write off was the situation when the repairs are more expensive than the agreed value of the car?!
I can't see how a new roof and shit, even considering it's a brand new, top of the range car, would cost >140k.
Yeah? No?
Yeah? No?
give me a second and I'll log into the shop :D I have current LOCAL and JAP FAST loaded there and I can acess a price database fairly easiily.
ok:
G3112-JF0MA - roof panel $1500
731D0-JF00A - roof reiniforcement $1000
73910-JF21A - Roof lining $1000.
79700-JF30B - rear Glass kit - unable to price.
thats a starting point. I have about half a page pf things that 'could' be damaged on it.
in reality I can see $10k in parts myself. especially if it got into the SRS and electrical system.
given that the car has curtains and seat bags and that the curtains are bolted from the rear of the car I'd suggest that they are also part of the write off quote.
power to someone buying it and fixing it. it certainly will not be a cheap evercise.
Guys, both quarter panels are gone, they are welded to the chassis, boot is gone, spoiler gone, roof gooooone, windscreen, interior is completely ruined including seats, glass has scratched the thing to pieces - at $60 k the repair would have to come under about $55 k to make it worthwhile. The car has had a very big impact so suspect some chassis damage, I wouldnt race it with that sort of damage, and at $60 k, do the math.......
get the angles right on camera and you could look as nuts as the boys off jackass...taking a chainsaw to the roof
when you're done hacking it off, whack an awesome cage in it (easy access), and then do a full carbon fibre roof.
job done.
edit - previous owner says it's bent like a banana....dream over.
Edited by tk80
looking further at that - rear quarters both sides ( I had these pegged for replacing.) and prettly much all the hardware attached to them.
G8100-JF0MA - REAR FENDER RH - $2600.
G8101-JF0MA - REAR FENDER LH - $2600.
    • @Butters I can't tell you why but the bigger HKS step 2 cams improved low and mid end immensely. Turbos started spooling about 1k RPM less than before and the idle/vacuum was rock solid, it was an absolute thrill to drive, 3rd gear pulls hit 180kmh where previously only managed 160. Conversely, the milder poncoms in there now have a funky idle making it harder to get off the line, drives poorly in lower revs, laggy and makes less power/torque throughout. Feels better after I swapped the EBC but unless I put it on the Dyno again, I can't say how much better.
    • Hi Sydney kid   do you still selling spring and blistein shocks for Nissan 260rs? Air any suspension upgrades? Please advice     yudy
    • Cams are not needed at this power level, they will create lag. The cam gears are a good idea though.
    • @Murray_Calavera yeah, I guessed as much, cooler temps, more boost, less knock, more timing, hello power. Unfortunately not quite within reach ATM, could upgrade my whole fuel system to support but still wouldn't have E85 to run it 😂  Anyway, I changed cams again, 260/260 poncam B and everything else the same except an EBC upgrade. Now I must say I was quite disappointed with the result as it was like running stock cams (didn't try to dial them in as they're supposed to be optimum already) but after awhile I suspected my new EBC was underperforming not to mention difficult to use. I recently swapped back my old EBC and it drives much better now, boost comes on sooner, more stable, no spikes etc, feels all quicker and faster than with stock cams. Planning to fiddle with the cam gears and see what happens but maybe skip the Dyno as I intend to revert to the HKS cams cos they really made the car come alive; low and mid end was unbelievable and it just wanted to rev to the moon, finally knew what people were raving about, RB26 really loves revs. Anyway, Dyno 03 is quite disappointing, in Dyno 02 although peak power was less and trailed off at the top, the low and mid end improvement more than made up for it.
    • @Darrel It's so tempting to say e85 is borderline magic. It cools the intake charge, so if you're flirting with the edge of the turbos compressor map it helps dramatically cool down the hot air the turbos are pumping. It is very resistant to detonation so you can crank the timing, I don't really want to say you won't be knock limited anymore.... but you probably wont be knock limited anymore lol. I wouldn't be surprised if you made 20% more power swapping to e85 (provided you have the fuel system to support them, bigger injectors maybe bigger pump etc).
