Tomei Reytec Ecu Software
lol @ downroad in the web addy
The reytechs are just a modified Standard ecu yeah?
Like nisstune but in a fancy case and 3 times the cost?
No they are more like a PFC d-jetro but better, one of the best ecu's on the market.
Ahk cool :D
I'd never really looked at them but when I did, I noticed that they exchange for standard ECU's
maybe they use them for the ECU plugs?
  • 7 months later...
  • 6 months later...
How so is it one of the best on the market?
I know it has the ability to run map sense, 30mins of logging with 5 channel graph output, vvt/vct controller...
How does it compare with Apexi Power-FC, HKS F-Con V Pro & Local offerings...
Whats the tuning resolution? Processor speed, etc...??
How has it behavedduring cold/hot start compared with other ecus you have tuned...
  • 2 months later...
