Close Open
Close Open
Engine Torque Dampers
11 replies to this topic
  • Gender:Male
  • Car(s):98 Supra RZ-S
  • Real Name:Peter
Hey guys,
Has anyone used or experienced using an engine damper to reduce the "rocking" when applying power/changing gears etc?
Seen some on G35Driver forum and these are the most common ones:
Stillen Engine Brace - Mounts lower to the block
Weapon R Damper - Mounts to the plenum
The 6 speed manuals would probably benefit from this more due to the shock in the driveline though I'm interested to see how a 5AT would feel.
Cheers,
Peter
Posted 24 October 2010 - 09:47 AM
  • Car(s):2003 Nissan Skyline 350GT
  • Real Name:James
Has anyone purchased one of these engine dampers to date??
i am also keen to possible buy one soon!
Posted 17 January 2011 - 04:07 PM
  • Gender:Male
  • Car(s):2011 Skoda Octavia vRS
  • Real Name:Iain
its more beneficial doing engine mounts instead of the damper which just moves the stress of the engine torque to a spot on the car that isnt really designed to take it. like the strut tower
Posted 17 January 2011 - 05:22 PM
"I don't always Nissan, but when I do, I Renault."
  • Gender:Male
  • Real Name:Peter
Have actually bought one from the U.S and it definitely makes a difference to my auto 350gt.
Sure engine mounts are a more permanent solution though I like to adjust my damper so it isn't vibrating like no tomorrow.
Posted 17 January 2011 - 06:34 PM
  • Gender:Male
  • Real Name:Iain
youre also moving vibration into the chassis that would normally be taken up by the engine mounts :)
ive had them before on a few cars, to be honest it make 3/5ths of 7/8ths of fcuk all difference.
Posted 17 January 2011 - 07:06 PM
  • Gender:Male
  • Car(s):V35 + GSXR1000
Never bothered with these before, my 180sx busted its engine mounts when it was throwing out 308rwkw but a set of nismo ones fixed that
doubt the VQ35 in its NA form is going to give the stock mounts any problems
Posted 17 January 2011 - 07:19 PM
1993 180sx 308rwkw 2nd car sold- "RIP SR20"
2005 Kawasaki Ninja ZX636 95kw for quick thrills - Sold
2009 Suzuki GSXR 1000
2003 Nissan V35 Skyline 5 speed AT 170rwkw stockish - Current ride <- QLDs only V35 time attack junky :P PB 101.68 QR sprint circuit, 105.18 Clubman
Australias 1st Quaife equipped V35 and probally the only auto in the country running a LSD
  • Cobey
  • Members
  • PipPipPipPip
  • 365 posts
  • Car(s):V35 Skyline 6MT Coupe
mind you if the megan ones are what they crack up to be its a cheap $400 (posted) investment!
Posted 17 January 2011 - 09:45 PM
  • Gender:Male
  • Real Name:Iain
i think nissan decided to make them from play-doh! S chassis factory engine mounts sucked big time. nismo FTW!
Posted 18 January 2011 - 08:52 AM
  • Gender:Male
  • Interests:boobies. u.mad?
  • Car(s):Girls car
  • Real Name:Matt
Engine dampers are particularly controversial, some say that it puts to much stress on the motor and its more detrimental to it than good because something has to give, whether its at the gearbox, or on the crank, but some say its fine.
Personally i dislike them, ive had one on my rb25det, and hardly experienced any change, i was more worried about losing more space in the bay since i saw no difference. the money is better spent else wear imo.
Posted 29 January 2012 - 09:28 AM
  • Gender:Male
  • Car(s):2005 V35 350GT
  • Real Name:Greg.
I think I would steer clear, as Iain said, you are placing stresses to parts of the engine and body that were not designed for it. Especially with the version that bolts on the plenum. I can't image it is good to put extra stress and flexing on an aluminium plenum which was really only designed to direct airflow.
Engine movement is fairly minimal with good mounts anyway, if you are getting excessive movement then it is probably best to fix the mounts rather than add a damper.
Posted 29 January 2012 - 01:16 PM
  • Gender:Male
  • Car(s):Girls car
  • Real Name:Matt
wait, wat? it bolts to the plenum?! hell no, stay clear of that shit, aluminum plenum does not = strong, i can see it ripping away from the head after a while. what a shit design...
Posted 29 January 2012 - 01:43 PM
  • Gender:Male
  • Car(s):350GT
Unless your using a true damper, rather than some hard rubber sandwiched between metal in a tube, its not worth the effort, they just transmit a lot of engine vibration into the body, and you will likely feel/hear it.
Posted 05 February 2012 - 06:22 AM
