Cant Edit Posts
Hi,
today i come on to edit some of my For Sale posts and the edit button at the bottom of my post isn't there. i posted a new reply to the thred today and the edit button is at the bottom of that one, just none of the other older posts i have made.
i have two For Sale topics at the momoent and cant edit either of them, so its not a problem with just the one topic.
does anyone know or have any ideas as to why this is? the help would be appreciated.
Thanks
Josh
Edited by QWK32
But out of interest - what did you need to edit in the posts. We are trying to work out what problems might be?
just removing items i've sold and adding new ones. also lowering prices.
You could just post up again with the updates?
People reading the thread will see it.
Reason being we have dodgy traders editing thier posts so its harder for us to track down goods sold, what type and so on.
fair enough. will do from now on, thanks.
I also had this "problem"
Can the 2 hour thing maybe just used in the For sale sections? It's a real pain in the a55 if you've made a spelling mistake or said something silly in another section :thumbsup:
Can the 2 hour thing maybe just used in the For sale sections? It's a real pain in the a55 if you've made a spelling mistake or said something silly in another section :rofl:
Shouldn't say some thing silly in the first place :P
How does freezing the post stop bad traders? All i can imagine it doing is shortening the life span of their login.. which means they just have to work a bit harder to cycle their logins and get them ready for posting.
From both a buyer and seller perspective it makes the Parts for Sale Section harder to use. Adverts with multiple items can go on for weeks and have a lot of responses. I will normally continue to edit my first post to make it easy for people to get the most up to date information. With the lock in place people will have to scour through the whole thread before they know if they're wasting their time. One might then think to post separate items in separate threads but then you introduce other problems because an add won't stay in the first 2-3 pages long enough for people to browse it. Most purchases are made through browsing.
thanks
Wegs
if you guys are so worried about not being able to edit your post SUPPORT the site that supports you
make a donation and all your problems are solved
good job CrazY_J i see some people the day they join they make a donation kudos to them
while some guys never make donations
so Kudos to you for making one :(
We're looking at ways to revamp the for sale sections at the moment - there's a whole thread discussing it in the mod section so it's not being ignored.
I understand that not being able to edit your listings is a bit of a pain but there is method in the madness, and as alluded to previously it means that someone can't just sign up and do the dodge on someone, then remove or alter the records of what they had offered for sale.
I know it's not perfect but it's the lesser of two evils until a "proper" fix is in place. Thanks for your patience guys :laugh:
I think the time limit is a great idea
if people really need to edit there items for sale then...
1) pm a section moderator with proposed changes the the relevant post
2) give a donation to SAU and get the extra's that come with that
    • Full results via link below https://docs.google.com/spreadsheets/d/1inu1mRRO0WjV2-3vGYsjnmYggVOzmApWOby68GwPGcI/edit?usp=sharing
    • Have I not posted since 2022 ? wow... Yes, it's pretty much finished mechanically. I'll probably sell it soon as the old man is 80 in November, so 99% he won't ever drive it again. I don't really need 3 GT-R's and I haven't driven any of them since September last year - correction, drove my 33 earlier this year on Australia day. All of them have been like this since then.
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
    • Anyone here know the answer?....missing since the w/e...
    • Google tells me that's a Japanese Rat Snake... 2m long? Man I think Australia has traumatised me to think all snakes are dangerous unless they're pythons. Also... "16 years later..." is that a record on SAU @PranK?
