Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
PM-R33
Hey guys
This originally started out as an idea in this thread ( http://www.skylinesaustralia.com/forums/Eo...S2-t333980.html ) but it is now going ahead so I figured I would make a new thread :)
This will be a group buy for direct carbon fibre replacements of the factory foglight/indicator surrounds as pictured here:
And should roughly look something like this once fitted:
These are being supplied by PSI Parts and we will need a minimum number of 10 people to start production.
Cost will be $119 a pair plus $11 Express post shipping Australia wide.
I will keep this group buy open until ten people are gathered.
If you have any questions please feel free to ask.
Please place your names below if you are keen and we can get production started :laugh:
Thanks guys!
Phil
BUY LIST
1. PMR33
2. EIRESGAUS
3. .......
4. .......
5. .......
6. .......
7. .......
8. .......
9. .......
10. .......
Edited by PM-R33
Nah, if you have a quick read through that original EOI thread I put up you will see how it all came together. To my knowledge these have not being available in carbon fibre anywhere before.
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT
5. .......
6. .......
7. .......
8. .......
9. .......
10. .......
Edited by PM-R33
There is 6 screws that hold the covers on. Not sure if you can just unscrew them to get the cover off and leave the whole housing still on the bumper. Last time I did it I just removed the whole housing and then once it was off the car unscrewed the covers. It wasn't hard.
I would assume the weave would be 2x2 twill weave as I think that is what all of their products use. I'll see what Shane says. I'm sure the quality will be great as the carbon cooling panel they are sending out next week looks perfect from the photos.
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT
5. SSXRICHO
6. ONEDGE
7. 75COUPE
8. .......
9. .......
10. .......
Edited by PM-R33
As soon as 10 people are gathered PSI parts will start manufacturing them as that is the minimum required. So there kind of isn't a date as such....is that cool?
If not I can put a date up, but we only need two people anyway so it would be a safe bet it would be filled this week.
    • 10-15 years ago, the answer would always be buy a good import motor and so many machine shops make.a hash of an engine rebuild, or they think they are some sort of RB magicians and want 40k.      Now as others have stated, you are buying a VERY old used motor. So rebuild is the correct answer.  Just finding a machine shop that will both do a good job and charge you a regular price is now your challenge.
    • SOLVED   simple solution. After wrecking by brain, i ended up jist giggling everything i could. At one point last week I noticed that the left side signals shut off for a split second. I wasn't sure what triggered it. I spent time cleaning up wiring, re-wrapping and adding DT connectors to my IC7 stuff. I bought a new hazard and stalk hoping that would work. The stalk did fix some function issue but not the steady on. Hazard didn't fix it. I started just tracing everything. Once I got to the engine bay I notice my engine harness was droopy. I started moving it and the signals flickered. Come to find out that the starter + turned off sigmals when it grounded out on a bolt I have a Wiring Specialties pro harness so I'm not sure if this is specific to it. So it should work proper once I hook everything up   20240511_190033.mp4
    • Both of those things are on my to do but not quite in a position to do that just yet until I can at least get it running back to stock. Going to work on getting the exhaust manifold gasket and studs replaced first, an obvious need it now. Then I'll try out the new maf and see hownthat does. After that I'm thinking cas if I'm still having the same issues. Still need to run the fuel out and refuel I'll change the fuel filter tomorrow along with cleaning the iacv with carb cleaner. If all else fails I'm going to get a serial port and see if I can get some sort of data on what the ecu is seeing when the issue is happening but really hoping one of the methods above work out first. After I get a good base I'm going link but have to save for that so it'll be a while for that based on my tuners suggestions. Definitely need the exhaust leak fixed first though car has always fallen flat after about 4-4500 rpm since I've had it and suspecting that's the issue. Then I can move forward with the rest.
    • My vote is rebuild s2 engine or maybe get a neo (but expect you may need to rebuild that too). Doing an engine conversion you would have to be a true tragic nowadays and actively be aware there's better/smarter options for value.
    • Or buy one someone built earlier! (realistically V8 mustangs or MKV supras are great). I see people nowadays putting ZF8's into MK4's, and people putting 370z gearboxes, diffs, axles into R and S chassis and it's like.... just get a 370z at that point and mildly boost the 3.7 instead of the 2L and away we go...
