Best Skylines Of Sau
Darmanin10
The Bayside blue R34 GTR has SSR Professor SP1's. Notice how the stud pattern blends into the spoke design. Same wheels as mine.
SP1's have a flatter spoke design whereas the Meisters spokes curve more.
The 3 Piece Work Meister will have the stud patterns separate from the spokes making the rim "look" smaller.
^ thanks for confirming!
whilst i am here, i may as well post another pic of my gtr hehe...here is a pic with the funky rear tail lights illuminated :) now with better quality image!
Edited by Marko R1
Fitment of filling out the guards look good.
What wheel size, offset and type of wheels you running?
wheels are 19x9.5 +30, axis wheels which have a lot of dish & surprising as light as japanese wheels when i looked the at wheel weight chart
Yeah right.
9.5 wide wheels sit so nice on a R32 GTR, fills it out nicely.
Welldone!
P.S. Since when do you venture out of the "Aussie Delivered R32 GTR's" thread? :laugh:
Yeah right.
Welldone!
haha this is true - most of my time these days is in the ADM thread - when i had my black gtr though, i lived & breathed in the forced induction "rb30 thread" - things change i guess :)
does anyone know what size rims were fitted to the s-tune gtr, as per this pic? look to be nismo lm-gt4's!
surprisingly, looks quite similar to my gtr (minus the stickers) which is pure coincidence :)
above r34 is a ztune not s tune, the rims are a custom offset lm gt4 made only for the r34 ztune but cant remember what the offset is exactly
i think mark was referring to the R32 S-tune in the pic he posted.
i find myself mistaking people's attachments for signatures in the new layout
Edited by alex182
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
