Fitting A 4wd-rwd Toggle Switch To An R32
Guest
I searched but couldn't find a write up of how to install a 4wd-RWD toggle switch on the R32. So after finding one on another forum and doing this mod myself today, I thought i'd contribute a little and write up how I did it.
It shouldn't take much longer than 20-30 minutes. If that...
I did find conflicting information about the actual fuse location. Some sources say its in the engine bay fuse box, other sources say its on the interior fuse panel.
Further research concluded to me that the engine bay fuse will remove 4wd only, while the interior fuse will remove 4wd and ABS/Anti-lock.
Tools / equipment needed:
- Phillips head screw driver
- Wire stripper / cutter
- 2 x lengths of wire for the switch (length will depend on where you put the switch, i used about 20-30cm for each wire)
- 2 x Female connectors (for the switch)
- 2 x Insulated wire connectors (to wire the switch in)
- A switch (i got mine from supercheap auto, cost about $9 but there are cheaper ones there)
1) Remove the interior driver side plastic under neath the steering wheel area.
2) Locate the fuse panel and the 4WD fuse. It will be the red 10A fuse in the top left corner.
Remove this fuse and start the car. The 4wd and Anti-lock dash lights should light up if you've taken the correct fuse out.
3) Turn the car off, replace the 10A fuse and remove the fuse panel. It is held in place with one screw in the left corner, and a plastic clip on the right side.
4) Behind the 4wd fuse, there is a blue wire with a white stripe. You will need to wire the switch into this wire so you can cut the circuit going to the 4wd fuse.
5) Cut the blue/white striped wire and connect one length of wire to each end. These will be wired to your switch. Connect the female connectors to the ends of these wires.
6) Work out the placement of the switch and run the wires to this location. I placed mine to the right of the steering wheel in one of the removable plastic bits. I had to drill a 12.5mm hole to fit the switch as per the instructions that came with it.
7) Connect the switch and test to see if it works. The dash lights should switch on and off and you should (i did anyway) hear an audible "woosh"... what i can only assume is the 4wd system depressurising and re-pressurising as the switch is turned on and off...(someone may need to verify this...)
8) Once you have it all working properly. Re-assemble the fuse panel and interior panels.
9) Enjoy :D
I hope this info is correct. Of course, feel free to correct me on anything and i'll fix it up.
Cheers,
Mark
Thanks for the kind words everyone :P
Birth:
As far as i know, yes it does. I mentioned this on the 5th line of the original post.
The Anti-lock light also comes on when i turn the switch off, which leads me to believe ABS is also disabled... not 100% sure if they're actually the same thing or not though haha.
As far as i know, the 4wd only fuse is in the engine bay... but it looked like it would have been a bigger pain in the arse to wire a switch into, so i just used the interior one.
I keep it 4wd most of the time anyway so im not too clued in on how it actually changes the handling of the car.
I did this mod mostly out of interests sake.... and boredom :mad:
Cheers,
Mark
  • 4 weeks later...
Spinning the wheels is fun so a toggle switch is the way to go. But after having a 4wd skyline I don't think I could ever go back to only having rwd. 4wd is so much fun on dirt, handling is insane. Also it just ploughs through the mud patches out on the farm when it rains. Ha ha!
  • 10 months later...
Wiring a switch to the 4wd fuse in the engine bay requires you to turn the car off and then back on to get 4wd back, but the incar fuse can be switch on and off whenever and shouldnt matter.
Something to do with the power feed to your 4wd computer in the boot.
Purely for w@nk factor, anyone know where I could get a fighter style switch? like where you have to pop a cap before the flip can be switched?
Superchump? Jaycar? Dickos? etc etc
I have one in my wagon for 2WD but be careful, if you have a 33 GTS4 you can't do it the same way the R32 guys do.
An even better way would be to leave the wire in tact and run some blades into the fuse position. I have done it that way before and the blades never fell out. Saves pulling the car apart and cutting the wiring. Also allows you to return it to stock with no evidence that you have been out flogging the ass off it in 2WD :D Only sort of downfall is that you will need to run a fuse in this wiring but thats not that hard. A proper fuse holder doesnt cost much and can be tucked away under the dash without to many issues
From memory you still need to switch the car off and restart it to enable the 4WD system to work again.... its been a few years since i have done this mod
In a 33 GTS4/GTR, 34GTR you will need to remove the front driveshaft as the 4WD system works differently
Edited by ido09s
Correct!
I've attempted this in my 32 GTR, however i quite like my ABS so i took the unit out.
There are torque split controllers that are much more effective at this task and do not disable ABS. I simply haven't gotten around to purchasing one :)
It is different but there is a technique to put it in 2WD mode without dropping the front shaft.
It runs a 5% preload whereas the 32 era doesn't, in the workshop manual it outlines the two methods of putting the car in 2WD mode. One is dropping the shaft, the other is disconnecting the air bleed plug and pumping the brake pedal 5 times after you start the car. It works so well that I installed a switch and drive around every day in 2WD (until I broke the gearbox doing too many skids on semi slicks, but that's another story).
Point is, transfer case is fine and 4WD works perfectly when I want it to.
When was the last time you changed the transfer case oil? What did it look/smell like?
5% isnt a lot but i dont know that i would want to do it every day. I would compare it to driving around with your brake pedal on 5%. See how long the brake pads/discs take to wear out. Even with 5% it will be wearing the clutch packs out prematurely.
the method he's describing (with disconnecting the air bleed blug and the 5 pumps on the pedal) put the car into a diagnostic/test mode and de-pressurise the transfer case. having said that though I thought there was some physical/mechanical (not hydraulic) pre-load in the 33 transfer case but maybe it is all hydraulic and is all removed doing the procedure outlined above. haven't bothered to play with 33s enough even when I owned them.
agree with brad though about using blade connecters and a fuse inline with the switch. that ways it's easy to remove and also easier to install. and yes 100% doing the in-cabin fuse there does disable both ABS and AWD. no you don't need to turn the car off to get AWD back, but you do have to come to a complete stop (then the system self checks. it needs the ABS/wheel speed sensors to be not moving to complete the self check properly, then AWD and ABS is re-engaged).
the poor mans switch is just switch the car off whilst car is moving over 20km/h. then turn it back on (still rolling over 20km/h). as the AWD/ABS system can't complete the ABS sensor check it goes into no AWD/ABS mode same as with the switch. good to use at the drags etc as you can pull your burnout etc and as soon as you come to a complete stop AWD re-engages automatically (no need to remember to flip a switch). again this ONLY works in R32 GTR and GTS4.
Not for a while but I would think over a year of driving around in 2WD that it would have killed my transfer case by now. There is NO preload on the transfer case with this method.
I'm not the only one do this, there are several of us in WA that KNOW it works - we even run cars up on the dyno like this.
Words don't describe my disappointment at not being able to do this with my car, I was amped!
You can!
    • Hey all. Had a bit of a scare today with my R34 GTT when i flicked on the tail/parker lights, and  some wiring started going up in smoke under the dash. The fuse didnt blow, it just melted the casing of the fuse so must have been a crap fuse? Previous owner did alot of wiring, some of which is quite sub par and the fuse that melted was definitely newer than the other ones that were in the fuse box, but didnt seem that he touched the wires that mainly got melted. Anyway may need a small section of a new loom, is there lots of similarities between the turbo and non turbo looms especially for under the dash stuff? The wired that got friend go into a 6 pin relay under the dash. The non turbo ones are less than half the price here from a wrecker and all i would need it the section that got fried and any other wires that are affected.  Thanks in advance
