M35's Wheels. What Wheels Do You Like On Your M35?
bLaQ.bOi
hey guys, i was deciding where to go with wheels on the m35 when it lands...
atm its got skyline wheels on it 18's
post up pics of what wheels you like on m35's or what wheel you HAVE put on your m35!
also, because its awd. does it mean i have to run the same rim size and width's all round?
Edited by bLaQ.bOi
Regarding width, yes. Rolling diameter seems to be very critical, not the 2-3% variation that other attessa equipped vehicles seem to allow.
If you're looking for a new home for those 18's when you find replacements, let me know, I'm after a set of those.
BTW, the car looks great, you must be busting to get your hands on it!
Cheers, Dale
yep ill definatly be selling them
if i decide to keep the car, or sell it and go after one with a sunroof like i wanted. im not sure
if i decide to keep it, it will be getting a respray asap. ill keep the colour on the low atm still trying to decide!
so need to run the same wheels. that sucks lol
anyone got any pics of thee cars with gangster meshies on them haha
vxss?
I'm sure there's a fella on here for NZ, coincidentally White with the Nismo kit, had 19x10 or 19x11 mesh of some sort, with seriously pulled wheelarches and very low. Maybe someone else can remember, his looked very tough indeed.
Yeah I reckon 19 - 20" for the M35, those arches are so big that they need some size!
To get a flush fit i used 19 x 8.5 +22 offset. these just fit under the guards without any rolling, and have plenty of clearance on the inside.
So you could definitely fit 9.5 +35 under the guards, but might be tight on the inside of the fronts. (there is loads of inside room on the rears) but I wouldnt recommend staggered on the M35
Here is how the 8.5 +22 offset fit.
Edited by bbenny
That looks awesome dude! Love the wheels, that's how I'd like mine to look.
Can I ask what size your tyres are? Is that with standard ride height as well?
Cheers.
Cheers.
Thanks mate :rolleyes:
Tyres are 225/40 19 Which is still a bit small from what I recall, so my speedo is off by a couple of %
It is a fair bit lower than standard, I have Tanabe adj. coilovers in there, so its probable about 2" lower than standard in those pics, but it sits a little lower now as the new springs have settled in.
Here is a shot of the front height (sorry its a crap phone pic I already had) - rear is the same.
I have these 19" x 8.5(see pic)....sorry about the tyre shine.
But looking at getting these!!....19" x 8.5
http://www.axiswheels.com/view-wheel/axis-super-hiro
They are sweet wheels! I had them on my C34 stagea. Awesome quality and great price
Only downside with the 8.5" is they dont have the concave spokes pulling in. Make sure you get the +20 offset (they come in +35 or +20)
I reckon the 9.5" +45 with a 10mm spacer would be sweet in the ARX that way you get some more dish and pull on the spokes. They are super aggressive and should just fit!
here is a pic of the 18x8.5" on my C34
Edited by bbenny
yeh I need dish.......don't really want spacers on it though....need the wheels to fit under without scrubbing at the height it is atm.....want to be able to get on the track very soon!
Edited by Jetwreck
Who is that Axis range available through in Australia?
From what I understand there is no distributor here in Aus.
I think Tempe Tyres brought a few containers in though a while back, so maybe try them to see if they have anything left. Late last year they had a handful of 19x 9.5 +45 in stock...
Jetwreck: I fricken hate spacers as well. get the right tool for the job!
speaking of which - has your nismo ECU arrived?
And on that topic, ecu's, has anyone spoken to Toshi on here regarding a re-map, I know he does the other Nissan ecu's and he's very good.
Edited by richzx
    • All the above effort, time, swapping out parts in the dark (i.e. no O2 data). You're literally running in the dark.
    • Looks like both of my cars have pressure switch issues. The R32 GTR has 18 flashes on the ATTESSA controller which is "ETS pressure switch circuit". The 4WD light is intermittent, and often just restarting the car clears it. There is an $300 replacement option https://www.ebay.com.au/itm/285675135148?itmmeta=01HXN3YKRGKQ08GRZ5KFKKZWJT&hash=item428390a0ac:g:6CcAAOSwWxBltMEG so if it becomes a permanent issue and I can confirm that the switch is the issue, i have a solution. The NM35 is reporting C1208, and disconnecting the switch causes the 4WD light to go away. Translating from the Japanese shop manual "when the pressure is reduced to 2.6MPa (377 psi) or less: conduction occurs when the pressure increases to 3.8MPa (550 psi) or less: conduction is present. Reference: • Immediately after the E-TS actuator motor stops, the pressure inside the accumulator is high and there is no continuity." Not sure how good the translation is but from what i can deduce this means the switch is normally closed (NC) and as the pressure builds from 0 to 550 psi the switch stays closed, then opens and 550 psi. As the pressure drops from 550 psi to 377 psi the switch stays open then closes again at 377 psi. Is that how these things work? These pressures are a lot higher than the R32 ("control pressure 0-228 psi") but i'm hoping i can find a generic switch (like they've done for the R32) to use as a replacement. Maybe something like https://www.ebay.com.au/itm/355586397452?epid=1676016964&itmmeta=01HXN534AF22ACTG6TGDDQGEQ7&hash=item52ca99d50c:g:mAEAAOSw8ilmBcMh&itmprp=enc%3AAQAJAAAA8LtWdNlWHgyJ%2F3cbw25S2A1lde3qBi3fJii4T3lQavCz4kpqiD42SmBa4FocMvXCjcxiowHjb8vZ8%2BWxc53BkHv781tkStSnCDaenfGKC3bIp0keK20dfsn9LoPa3TfqaEmAydqqyKobgTdXsGGzsl%2BRjOVGuD8OIpOv%2B0wMl7aUtHg0iJtojbtzA%2BRS8Xfm8Ufjuvz4niwrqglAXFUbkL6J%2FGuHPeeECZhLBBN3iNM1Swl94Fv5zE95YK%2B5O6dxDN1ySNOjdMxkA8yaprbuwRHFQv1nlGh%2FWjekj6EUFR2%2FO4HTsoKtSAkY0Mj1w1uf1w%3D%3D|tkp%3ABk9SR6zFjKXtYw but with a lower close pressure, and thread adapter if required. Am i dreaming?
    • That is a dead f**king short of B+ to ground. Scary.
    • 10-15 years ago, the answer would always be buy a good import motor and so many machine shops make.a hash of an engine rebuild, or they think they are some sort of RB magicians and want 40k.      Now as others have stated, you are buying a VERY old used motor. So rebuild is the correct answer.  Just finding a machine shop that will both do a good job and charge you a regular price is now your challenge.
