Rb26 Cams In Rb25
18 replies to this topic
  • Gender:Male
  • Car(s):240sx rb25det! Rb30det.
  • Real Name:jerry
i have a pair of rb26 cams in my car with cam gears. the concern that i have is that my car has hardly no vacuum on the boost gauge which i guess has another problem with startingt the car aswell. is it safe to say i would are should do solid lifters???
Posted 04 May 2010 - 03:04 AM
  • Car(s):Nissan 200SX S14a
  • Real Name:Brad
Absolutely. RB26 cams should be used with solid lifters.
Posted 04 May 2010 - 11:11 AM
  • Gender:Male
  • Car(s):A31,S13,C33
  • Real Name:Adam
Here are the specs:
Posted 04 May 2010 - 11:17 AM
  • bubba
  • Members
  • 19,209 posts
  • Gender:Male
  • Interests:Paintball bishes.
  • Car(s):R34 coupe & RS4Vs2
The major difference between the cams (aside from durations and lift) is that the 26 cams are profiled for solid lifters and as such have different ramp rates to the cams meant for hydraulic lifter heads.
Posted 04 May 2010 - 11:39 AM
  • Gender:Male
  • Real Name:jerry
So would they mess up anything are would it make the car not run right???
Posted 04 May 2010 - 02:04 PM
  • Gender:Male
They make the car loose about 50kw, as they pump the lifters up. Unless you use solids
Posted 04 May 2010 - 05:22 PM
R32 gtr Rb30
Eagle rods, custom sump and plenum
Arias Pistons, Toda 272 10.2mm cams
Sard 720cc inj, MSD Cdi
Ported head, HKS T45s, HKS 50mm w/g
100mm HKS intercooler 100mm throttle body
355mm AP discs 6 piston Porsche Brembos
Nistune live mapping, hoping for 450AWKW
  • Gender:Male
  • Real Name:jerry
would that also be a reason for my car not having the much vacuum???
Posted 04 May 2010 - 11:33 PM
  • Gender:Male
Yes
Posted 05 May 2010 - 07:12 AM
R32 gtr Rb30
  • Gender:Male
  • Car(s):HR31 GTS-R, R33 GTR VSPEC
RB26 cams into a RB25 head are more grief than they are worth as you've found out :rofl:
Posted 05 May 2010 - 07:21 AM
CARS:
HR31 GTS-R - Racepace built, RB26, 280rwkw @ 1bar
R33 GTR - Racepace built, 365rwkw @ 19psi
Claims to fame:
Fastest Time ever on Mega Mini Wang, first go. No R-Comps, No Cheater test days, No warm-up runs
  • Gender:Male
  • Real Name:jerry
yea it is. so if i get 5he lifters then i would be ok??
Posted 05 May 2010 - 08:21 AM
  • TiTAN
  • Members
  • 19,866 posts
  • Gender:Male
  • Car(s):Evo 7
You could you know put the stock RB25 ones back in there, save yourself a bit of work and end up with something better.
that or just get some tomei poncams instead similar money to the solid lifter conversion and you end up with better cams (assuming you aren't going to put some massive cams in later?)
Edited by TiTAN, 05 May 2010 - 01:23 PM.
Posted 05 May 2010 - 01:21 PM
Buy my car, it will please sweet baby rajab greatly:
Mitsubishi EVO 7 (Making 249kw) http://www.skylinesa...-7-249kw-on-98/
  • Gender:Male
  • Real Name:jerry
i have a friend that has a set of stock rb26 lifters i may use those cuz i think the rb26 cams are a good cheap upgrade so i want to try it out but i want to do it right.
Posted 05 May 2010 - 10:11 PM
  • Gender:Male
Im fairly certain you need more than just the rb26 lifters, as the valve heights are different
Posted 06 May 2010 - 01:07 PM
R32 gtr Rb30
  • Gender:Male
  • Car(s):Laurel, VK TT LS1, Grange
  • Real Name:TRENT
dont forget you will need to shim the solids to get the clearance right.... and swap out the springs just in case they are a bit soft (common rb25 issue).
Posted 06 May 2010 - 01:11 PM
  • Bunta
  • Members
  • PipPipPipPipPipPipPipPipPipPip
  • 4,020,686 posts
  • Gender:Male
  • Car(s):R32 GTR, SP23
  • Real Name:Andy
buying pon cams will probably work out at a similar price when you factor in the labour of setting up a solid head correctly..and will be more of an upgrade.
Posted 06 May 2010 - 01:14 PM
  • Gender:Male
  • Real Name:jerry
so basically i should put my old cams back in and get a rb25 cam upgrade..
Posted 06 May 2010 - 01:16 PM
  • TiTAN
  • Members
  • 19,866 posts
  • Gender:Male
  • Car(s):Evo 7
yep.
Posted 06 May 2010 - 01:28 PM
  • Gender:Male
  • Car(s):E46 M3 & YZF-R6
  • Real Name:Phil
What is the rest of your setup?
Posted 06 May 2010 - 08:53 PM
Engine
Rebuilt/Heavily Ported/Polished Head, Tomei Poncams, ARP Head Studs, Performance Valve Springs, HKS GT-RS Turbo,
Greddy Intercooler, Blitz BOV, 40mm Alloy radiator, Vipec V44 ECU, Plazmaman Plenum on Chromed Runners, Plazmaman 72mm throttle body,
Blitz Nur Spec 3" Exhaust, Splitfire Coilpacks, Nismo 555cc Injectors, Tomei Fuel Pump, NOS Wet Fogger Kit, NOS Purge Kit,
Greddy Profec B Spec II EBC, Stainless Oil Catch Can with Braided Lines, Carbon Cooling Panel, Motul 300V Chrono Oil
Wheels/Braking
18" Volk Racing GTC's, Wilwood 6 Piston Billet Calipers, Wilwood 330mm Two Piece Rotors, Hel Braided Brake Lines, Motul Dot 5.1 Fluid
Suspension/Drivetrain
Tein Super Street Coilovers, Greddy Strut Brace, Whiteline Camber/Caster Bushes, GTR V Spec A-LSD, Whiteline Diff Pineapples,
Whiteline Front & Rear Heavy Duty Swaybars, Exedy Cushioned Button Clutch, Hicas Lock Bar, Redline Shockproof Gearbox Oil
  • Gender:Male
  • Real Name:jerry
the motor is stock but its a Frankenstein. i have r33 turbo head with a r34 n/a block currently with rb26dett cams. but those are gonna come out. i have turbonectic t76 turbo with rb26 manifold a/c running e85 with dual pumps an 1000 cc's all put in an s14 shell.
Posted 10 May 2010 - 01:15 PM
