its hard to tell in the pics just how far it is turned. Let us know how you go.
If im following along correctly. You purchased a low k'm stock bnr32, fitted some wheels I will assume they are a square set of wheels and tyres eg same width and offset and tyre size front and rear, if they are square then you haven't change your handling from factory but have more grip. You fitted some coilovers and wound them lower now have more negative camber and a firmer ride with less body roll. Now if you want sway bars this will bring in the oversteer understeer choice. A larger stiffer rear swaybar by it's self will cause more oversteer, how much effect this will have will depend on your coilover spring rates, If you feel like your car understeers right now and you don't like it a aftermarket rear swaybar might be what you need. I would recommend fitting front and rear swaybars with adjustable ends to keep a more balanced setup and can be fine tuned by moving the end links in different holes.
@Duncan whats the easiest way to remove the flare?
