My Wmi Install
  • Replies 52
If you need/want a large tank. i have the snow performance 9.5L (2.5gal) tank the last time i threw some fluid in it was 4 or more months ago and i only filled it up half way, still has ~1/4 left.
Any updates mate? i really wanna go water/meth injection while my car is in 4 billion pieces.....how do you rate it? also what are the major differences between the stage 1/2/3 kits, prices seem to bounce around ALOT on ebay....
Aiden
  • 1 year later...
OK, thread raised from the dead.........I made 301.5rwkw today on a DD dyno.
I drove it around without a tune [that used the WMI] like forever...............it wasn't knocking and the car was making good power etc and I am a bloody busy bugger!!!
But I finally made the time and had it tuned. Run before tune made 270rwkw, then we kept adding timing and pulling fuel out until we had a good overall balance and got 300 on 16psi for the final run. I probably could have got more if I wanted to up the boost to say 18-20psi, but considering my motor is not built, I didn't think it was worth the risk.
I'll scan the plots and post soon.
Apologies to all who were waiting for this, I just couldn't get to it any sooner.
Well there is 10% more power, and I know that the curve is fatter in all area's, and seat of the arse says it definitely feels quicker all round, but that can be considered as being all pretty subjective - by some. Honestly making more power was a bonus, I really wanted fuel taken out [it was riched up to counter bad knock levels = the reason I went WMI]- so a better tune.
WMI is really just a band-aid for ineffective or insufficient cooling :/
Your fixing the symptom not the problem, but if it works it works.
I considered it but decided against it for the reasons above.
Happy hunting.:banana:
What problems have you encountered so far with the wmi system....if any?
I have a brand new kit tucked away........somewhere...hmmmm :unsure:
None, love it, works faultlessly.
And no its not for inefficient cooling alone, it is for too high a compression, low fuel octane, and an extra 30rwkw. Where I experienced knock had nothing to do with overheating. However having said that, the heat and burn rate inside the combustion chamber was likely not as controlled as it should have been. But when you are ramming more of everything into it [fuel, boost etc] then it is to be expected at some point. There are other solutions to solve it [E85, lower compression pistons /thicker gasket, smaller turbo etc], but I chose WMI
Dyno charts attached.
  • 8 months later...
Hey Trident,
Reviving your thread for some quick info
Im about to get my SRDE+T on the rollers and am considering a WMI kitup for myself, however I am thinking about it on a boost fed pre turbo arrangement with a very fine low pressure atomiser
Can you tell me the relative water use of your system? And can you tell me did you need to run dual maps to run with/without or was your tuner able to simple have a boost down area of the map and boost up area which needs the WMI?
I was hoping I could tune to the pre 12psi region without WMI and then the tuner goes hard from 12psi to whatever he can get using distilled water alone
It would be good to hear your thoughts having done it yourself :thumbsup:
my WMI setup turns on at 8 psi and goes to full flow at full boost, having a 9.5L water meth tank in the boot i find i only have to top it up once every 6 months - 1 year
though that will increase if you are the kind of person that gets right into it every time its driven.
the smaller tanks just check the level when you fill up or once a month if you arent a flat footed user (alternatively install a float switch into the tank to turn on a low level light on your dash when the tank gets down to 1/3-1/4 left)
if your WMI setup supports map based turn on/off, set it to come on at 12psi or a little before and then full at your target boost, that way the WMI isnt active below that point and there is no chance the tuner will go all out relying on the WMI to keep it safe below that point, alternatively if your ecu supports it, get the tuner to setup two iginition maps and have a switch between them, one tuned without the WMI and one with it, (you could even set the switch to turn the wmi system off and on as switched)
unfortunately my car is running a microtech, I am on the 'buy a house' budget now and cant afford to change it again
my thought is to have an airtight tank under bonnet with a barb on the top and a barb on the bottom
top barb has a check valve and a ball and spring like a turbo tech to regulate when boost can pressurize the tank, bottom barb runs direct to the atomiser which i will mount into the suction pipe on the turbo.
as the system hits target boost pressure the turbotech will open and push the water through the bottom side of the tank spraying its mist into the non boosted intake stream
thus the dual map idea isnt going to work too well unless i am manually switching... plus i dont think the microguess has dual map capability (i am surprised it can window in and out....)
good to know it doesnt consume it too quickly, I would probably end up with a 5 or 6L underbonnet tank if i was to go ahead with it and just want to know it will last atleast a week of heavy driving or atleast one full track day.
fair enough.. Im still in consideration stage at the moment.
the setup is a .86 28RS on an internally standard SR 10:1cr, im wondering now if the WMI will help me go beyond the compressors usual envelope or if it will just get me there more comfortably
being able to fill up anywhere and just keep going has been a priority to me in the past, it shouldnt change but i do have the power bug afterall.
Pre-compressor induction of the water spray is a different sort of science. And wait for the comments about wearing out impellers etc. It is apparent that you have to do it right, but it will work.
Sizing your nozzle correctly should yield a water:fuel ratio of somewhere around 15-20%
Some setups work better than others, and there are a couple of forums about dedicated to WI. Great pictures, and more than a few variations that will give you an idea of what you want.
    • Cheers Lads Looking at changing up a few things maybe go 2.8lt, bigger injectors with more a modern Turbo. Possibly transbrake and convert to E85 with Haltech ECU. Any thoughts on those Mods changes or better ideas? Want to try keep the car Street/Strip While also being weekend drivable still.
    • The time has come, once again, for us to celebrate all things GTR! Motive DVD's GT-R FESTIVAL for 2024 is fast approaching, and we couldn't be more excited to be part of this awesome event once again! As usual, SAU NSW will be be part of the event, with our traditional club display on the day! If you would like to be part of it, firstly, you'll need to make sure you secure your Display Entry into the show via the below link by Motive Video: https://gtrfestival.com.au/ Other tickets are also available, ie. VIP Entry or Drag Entry, for you to also choose from. Once you have your ticket locked in, make sure to send us a PM via Facebook so we can add you to our list of display cars! When you message us, we will gather some more details from you to make sure we can spot you on the day, and guide you to the right place! If you'd like more information regarding the day, please refer to Motive Video's event page, or, you can get in touch with us and we will help you as best as we can. As always, general details are below: Date: Friday 24th May / Saturday 25th May Location: Sydney Dragway Time: 6.00pm Friday / 9.00am Saturday We look forward to seeing you all on the day! One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAUNSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're a bunch of suspicious skeptics here. So when we see a new user describing themselves as a "guy" but showing "Female" in the bio, we immediately suspect "bot" and "spam". If you are legit, then welcome. If you are a spambot, then die in an AI fire. No offence (unless you're a bot). What car did your dad drive when he met your mum? (Call this a car forum Turing test, if you like). What car did your mum drive when you started school? What car did your date drive to your first formal/prom/whatever. What do the majority of the license plates in your local area have on them (the state motto, the county motto, whatever)?
    • Howdy All! Minutes from this year's AGM attached! Thank you to the old committee for a great year & good luck to the new (*cough* same) team for the year ahead! See you all soon!   SAUNSW_2024 AGM Minutes_04052024.pdf
    • Hey guys! Just rolled into this awesome community and let me tell you, I'm stoked!  Cars have been my jam for as long as I can remember, and there's nothing I love more than talking about them. It doesn't matter if it's the latest performance mods, DIY hacks that'll blow your mind, or just nerding out over engine specs –  I'm all in. I know I'm the new guy here, but I promise I'm not all talk. I want to be a part of this community, learn from the veterans, and maybe even make some friends along the way. So, whether you've been wrenching on rides for decades or just getting started like me, feel free to say hi, share some advice for a newbie, or just throw out a random car fact (because, let's face it, those are always fun!). Looking forward to getting to know you all and becoming part of this gearhead family! Thanks Pihu
