Catastrophic Transmission Failure In A 2900km Stock Gt-r
I hate to be that guy, but a highflow that doesn't need a change of downpipes (i.e you need to buy the HPI downpipe or similar, which is good) And 98? Just.... be happy with 270kw. Unless you want E85 which for a daily is something you'll probably CBF running the gamut on in 2024. Just hyper expensive and limited in practicality. All the over 300kw setups are running E85, or external gates. You can imagine E85+External Gate changes things a lot. You can run gates off the stock manifold, or the stock turbo housing even... but you start getting into the "Why don't I just run a different manifold" discussion pretty fast. The LINK ECU is the goods. They fill a similar niche as the Haltech but haven't quite generated their own tax yet. The benefits over a Nistune are really notable if you want to be a tinkerer - there's a lot of custom stuff that goes on in cars like these when you change stuff. A tuner with nistune is good, but you really need tons of cycles and driving around, and different weather and all these circumstances that a dyno just can't dial in. The link will help you do that and get modified cars driving like factory cars.
I'm much more positive on downsized turbos these days. Probably not a fan of these V6 turbos because they're a packaging nightmare but an I6 turbo vs modern NA GDI DOHC V8 is pretty comparable these days in terms of general pain in the neck for some reason. -
Yeah, but it's not a good motor as used in the donor car. Low revving and low power, courtesy of tiny camshaft lobes, as per all other Nissan V8s. You have to tear them to pieces and put them back together the way that god intended before they're any good.
My Mrs has a Kona N and it’s a fantastic car to the point I’m looking for an i30N. Best part is they are still under warranty even if they break at the track!!! Find a bmw or VW that will offer that
How is the all Japanese infotainment system? Can convert to English?
