Japan Trip, December 2009
N1GTR
These Kill Your Facebook pics lol...
I wish i went with you guys....Cant say the offer wasn't there :) Im stupid lol
Yep, you said it hahahahahaha
Check the stalkbook pics now, ive finished uploading (finally)
