Yellow Jackets Coil Packs - Aussie Stock - Express Post - Best Price World Wide!
Yellow-Jackets-Promo-Cards--Concept%20co
We are proud to offer Skylines Australia the worlds best priced performance coil packs.
With thousands of sets sold worldwide, these are proving to be very popular and have been on the market for around 8 years now with some very impressive results.
Here is what one of our happy customers had to say about them:
I've been running these Yellow Jackets now for 3 months in my R33 GTR. Still no problem with spark blowout as I previously did with the old coils, and still plenty of power!
Done 2 HARD track days with no problems at all. Even added extra timing. Now at 28deg at 8000rpm WOT! Over 320+kw now!
I have now bought a second set of Yellow Jackets for a mates R32 GTR which had a constantly changing misfire, even after gapping the plugs to 7mm and replacing them. He wanted to upgrade the turbo's for higher boost, so I said he would have to change the coilpacks. He was dubious that this would fix ALL his problems, so the turbo's were fitted. No improvement of the misfire after installing the turbos, running them in and resetting the ECU. So I fitted the coils, gapped the plugs to 1.1, and reset the ECU. He didn't believe me that this was going to work, but low and behold, smooth idle, acceleration, and cruise!
He couldn't believe the difference in the 'seat of your pants' feel in acceleration (stock boost).
Going to do a dyno run soon to see what the difference at stock boost is compared to original figures. Then a re-tune and add a boost controller.
Bang for buck, these Yellow Jackets cant be beat!
Unfortunately, out doing a "road test" in the R33 GTR, with the street tires, and now with bucket loads of extra torque, managed to break second gear. Same sort of use/abuse with the old coils packs couldn't produce the same 4 wheel power slides, just under heavy acceleration!
Luckily I had a spare gearbox, so I could make it to the track days.
BENEFITS:
- Increase in torque.
- No spark blowout at higher boost.
- Improved throttle response and smoothness.
- Increased Ignition Performance.
- Improved Combustion.
- Direct Fit.
- 2 Year Warranty.
- Solid Construction.
- Cost effective.
SATISFACTION GAURANTEED
Manufactured with Components from GE (USA), BASF (Germany) and Epoxy Resins from Switzerland.
EXCLUSIVE ONLY TO PERFORMANCE-WISE
YELLOW JACKETS COIL PACKS PRODUCT RANGE:
YELLOW JACKETS COIL PACK SET - YJ-RB202526-S1 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6.
- DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN RB MODELS:
SKYLINE R32 GTS-YHR31/HCR32/HR32-RB20DE (1989>94)
SKYLINE R32 GTST/4-HCR32/HNR32-RB20DET (1989>94)
SKYLINE R32 GTS25-ECR32/ER32-RB25DE (1991>93)
SKYLINE R33 GTS Series 1-ENR33/ER33-RB25DE (1993>95)
SKYLINE R33 GTSTSeries 1-ECR33/ER33 RB25DET (1993>95)
SKYLINE R32 GTR-BNR32-RB26DETT (1989>94)
SKYLINE R33 GTR-BCNR33-RB26DETT (1995>98.)
STAGEA WGNC34 (AUTECH)-RB26DETT (1997)
CEFIRO A31/CA31-RB20DE (1990>92)
CEFIRO A31/CA31-RB20DET (1990>92)
CEFIRO LA31-RB20DE (1990>94)
CEFIRO LA31-RB20DET (1990>94)
CEFIRO LCA31/LNA31/NA31-RB20DET (1990>94)
CEFIRO EA31/ECA31-RB25DE (1992>94)
LAUREL HC33/HCC33-RB20DE (1991>93)
LAUREL HC33/HCC33-RB20DET (1991>93)
LAUREL HC34-RB20DE (1993>94)
LAUREL EC33/ECC33-RB25DE (1991>93)
LAUREL GC34-RB25DE (1993>94)
LAUREL GC34-RB25DET (1994)
LAUREL GCC34-RB25DE (1993>94)
LAUREL GCC34-RB25DET (1994>)
YELLOW JACKETS COIL PACK SET - YJ-RB2526-S2 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
SKYLINE R33 GTS Series 2-ENR33/ER33-RB25DE (1995>98 )
SKYLINE R33 GTST Series 2-ECR33/ER33-RB25DET (1995>98 )
SKYLINE R34 GTR-BNR34 - RB26DETT (1999+)
STAGEA WGC34 (2WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DET (1996>98 )
CEDRIC/GROLIA ENY33-RB25DET (1997>99)
LAUREL GC34-RB25DE (1994>97)
LAUREL GC34-RB25DET (1994>97)
LAUREL GNC34-RB25DE (1994>97)
LAUREL GCC34-RB25DET (1994>97)
LEOPARD JENY33-RB25DET (1997)
YELLOW JACKETS COIL PACK SET - YJ-RB2025-N - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- DIRECT REPLACEMENT FOR THE FOLLOWING RB NEO MODELS:
SKYLINE R34 GT ER34/ENR34 - RB25DE NEO (1998+)
SKYLINE R34 GTT ER34 - RB25DET NEO (1998+)
STAGEA WHC34 - RB20DE NEO (1997-1998)
STAGEA WGC34 (2WD) - RB25DE NEO (1997+)
STAGEA WGC34 (2WD) - RB25DET NEO (1998+)
STAGEA WGNC34 (4WD) - RB25DE NEO (1997+)
STAGEA WGNC34 (4WD) - RB25DET NEO (1998+)
CEDRIC/GROLIA ENY34 - RB25DET NEO (1999+)
LAUREL HC35 - RB20DE NEO (1997-1998)
LAUREL GC35/GNC35 - RB25DE NEO (1997+)
LAUREL GC35/GCC35 - RB25DET NEO (1997+)
YELLOW JACKETS COIL PACK SET - YJ-RB20313233 - AU$420.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6. (NO HARNESS ADAPTORS REQUIRED).
- DIRECT REPLACEMENT FOR THE FOLLOWING RB20 MODELS:
SKYLINE HR31-RB20DE (1985>89)
SKYLINE HR31-RB20DET (1985>89)
SKYLINE YHR31/HCR32/HR32-RB20DE (1985>89)
CEFIRO A31/CA31-RB20DE (1988>90)
CEFIRO A31 CA31-RB20DET (1998>90)
FAIRLADY Z PZ31/PGZ31-RB20DET (1985>89)
LAUREL HC32-RB20DET (1986>91)
LAUREL HC33/HCC33-RB20DE (1988>91)
LAUREL HC33/HCC33-RB20DET (1988>91)
YELLOW JACKETS COIL PACK SET - YJ-SR20-S1 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4.
- DIRECT REPLACEMENT FOR THE FOLLOWING SR20 MODELS:
SILVIA/200SX - PS13/KPS13 - SR20DET - (1991-1993)
SILVIA/200SX - S14/CS14 - SR20DET - (1993-1999)
180SX - RPS13/KRPS13 - SR20DET - (1991+)
YELLOW JACKETS COIL PACK SET - YJ-SR20-S2 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
SILVIA - S15 - SR20DET - 1999-2002
X-TRAIL GT(Jap Spec) - SR20VET - 2002-2007
YELLOW JACKETS COIL PACK SET - YJ-CA18 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4. (NO HARNESS ADAPTORS REQUIRED)
- DIRECT REPLACEMENT FOR THE FOLLOWING CA18 MODELS:
BLUEBIRD U13-CA18DE
BLUEBIRD U13-CA18DET
EXA N13-CA18DE (1987>91)
EXA N13-CA18DET (1987>91)
SILVIA S13/KS13-CA18DE (1988>91)
SILVIA S13/KS13-CA18DET (1988>91)
180SX RS13/KRS13-CA18DET (1989>91)
YELLOW JACKETS COIL PACK SET - YJ-VQ35-S1 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN MODELS:
SKYLINE PV35/CPV35 (03-06)
SKYLINE V35 250GT/300GT VQ25DD/VQ30DD
SKYLINE V36 SEDAN (up to 2009)
SKYLINE ©PV35 350GT (VQ35DE, 06/2001 - 09/2007)
STAGEA NM35 250T / AR-X FOUR (VQ25DET, 10/2001 - 08/2004)
STAGEA : PM35/PNM35 (01-07)
INFINITI FX35 (03-08)
INFINITI G35 COUPE/SEDAN (03-07)
INFINITI M35 (06-08)
M35 VQ25DET (06-07)
FAIRLADY Z / 350Z Z33/HZ33 (Includes roadster) - (03-06)
350Z Z33 Touring Series 1 (VQ35DE, 12/2002 - 01/2007)
350Z Z33 Track, Series 1 (VQ35DE, 12/2002 - 01/2007)
FUGA : PY50/PNY50/Y50
CEFIRO A33 (99-02)
LEOPARD Y33 (97-99)
CEDRIC Y34 (99-04)
GLORIA Y34 (99-04)
MAXIMA (02-08)
YELLOW JACKETS COIL PACK SET - YJ-VQ36-S2 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- FACTORY RUBBER BOOTS AND INTERNAL SPRINGS REQUIRED.
VQ35HR & VQ35DE 3.5L V6 / VQ37VHR 3.7L V6 / VR38DETT 3.8L V6 :
R35 GTR VR38DETT (08-12)
SKYLINE PV36/V36/NV36
SKYLINE V36 sedans PV36/KV36 (06-08)INFINITI G35 COUPE/SEDAN (03-07)
INFINITI EX35 (08-Up)
INFINITI G37
TEANA PJ32/J32
MURANO PZ51/PNZ51
FAIRLADY Z Z33/HZ33 350Z (Includes Roadster) - (07-08)
Z34 (370Z) VQ37VHRFUGA PY50/PNY50/Y50
FX35 (09-Up)
M35 (08-09)
ALTIMA SEDAN (07-12)
ALTIMA COUPE (08-12)
MAXIMA (09-Up)
MURANO (09-Up).
V36 VQ37VHR (2008-Up)
YELLOW JACKETS COIL PACK SET - YJ-VG30-S1 - AU$450.00 delivered within 2-3 business days - Addtocart.gif
- DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN MODELS:
VQ Fairlady Z (300ZX) Z32/GZ32/GCZ32 - VG30DE & VG30DETT
Front print - Plain back.
100% pre-shrunk cotton.
Available in White or Grey only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
- The link next to each item will take you to our site where you can view pics & details and where you can purchase & pay via Paypal with our secure online checkout system.
We also take direct deposit, bank check or postal money order. Please PM me for details.
Please PM or contact us if you have any questions regarding these items.
Cheers,
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
  • Replies 217
Hey can you pm me when you release these aswell? have you ran them on stock 34 neos yet?
No probs, I will be sure to let you know.
Weve ran them on a couple of GTTs and GTs both with mild mods so they should be fine on a stock setup.
Im still chasing another tester for these so we can get more varied results.
  • 2 months later...
Hi there, wanting to purchase a set of these for a SKYLINE R33 GTST Series 2 - ER33-RB25DET (1997).
Just want to confirm that you have some in stock, and ask how they're shipped (courier or auspost e-parcel) please?
Thanks,
wil..
Hey Wil,
I have plenty of stock of all types and I send them via Aus Post (Express Post - 2 business days to Sydney and within NSW).
Cheers,
Paul.
:blink:
Thanks Paul, will order asap. Tried twice just then, but paypal seems to be doing some sort of maintenance and keeps crashing out on me just before I get to confirm payment. There's no record of payment in the system so, hopefully I'm not out $780!
Will try again after 2pm Sydney time (which is the end of paypal's scheduled maintenance..).
I just did a "mock" purchase from my sire using paypal and it seems to be up and running.
Let me know if you have any more issues and I will arrange to send you an invoice via paypal.
Cheers.
    • Totally agree here @groovezog! There's advice and there's advice, sometimes the latter doesn't take inconsideration use case, budget, time, effort etc. If we all wanted the ultimate track car with a dry sump, big displacement, we would just go to the nearest Porsche dealer and buy a 911 GT3 RS (that's if they even let you these days lol).
    • There is absolutely no way to tell. What we can tell you is that it is an RB. It has a single, low mounted turbo, so it would seem likely that it is an R20 or 25, but it has RB26 inlet side and valve covers. As it is clearly a frankenstein, it could be absolutely anything. It is unlikely to be good, unless the person responsible for the painting was not also responsible for the engine. That bracket is not a bracket and it is not broken. It is the top end of the suspension upright, connected to the outer end of the front upper control arm. It is your suspension. Take the wheel off and look at it.
    • I took the liberty of downloading the pictures:
    • Hot plugs not being a good idea in a massively boosted engine?
    • Put some more sleeve/hose over the top of the brake line for protection and let it rub? Make a plastic or metal nozzle to provide the last little bit of length of duct. The nozzle made to clear the brake line, the cooling air hose shortened to keep it away from the brake line? Make a short hard line to move the end of the brake hose away? (by far the best of the easy options).
