Toyo 888 20 Inch
handbrake
  • Replies 43
Posted Images
Has anyone looked into the Falken FK452s for the GT-R? They are 255/35 and 285/30 resulting in overall diameter of 680 and 687 mm. Apparently they won a recent wheels tyre test. They are lower profile than standard though. If theyre cheap and as good as they say they are then they may be a good option.
You could also match up their 305/25 with their 255/30 fronts for an identical diameter of 661mm however I'm not sure this would really help the balance of the car.
Edited by fungoolie
A couple other questions:
Does the lower sidewall height on the lower profile non run flat compensate for the stiffer sidewall on the taller runflat? I'm just curious as to how this will affect the ride/handling. If you were too look at this 30r/35f profile combo instead of the 35r/40f you suddenly jump up from having a choice of about 4 road tyres, Bridgestone, Dunlop, Pirelli, Michelin to about 40 on the tire rack website.
Does anyone know what rolling diameter difference front/rear the GT-R can handle?
Going down this route for a daily driver gives me the ability to buy a 300 to 500 treadwear tyre for prices ranging from US$119 to US$250 compared with US$400 for the Dunlop and Potenza standard runflats.
Also any thoughts on what your insurance company may say if you change to non run flats?
Thats why the base model GTR IE less run flats, leather trim and bose is lighter, but the manual says its only 10kg lighter.
Base model has run flats and leather. Only the bose is missing and they replace it with crummy gear which probably weighs very similar amounts.
My JDM base model 2008 doesnt have run flats or the full leather trim.
What did they replace the standard Bridgestone or Dunlops with when they brought it in? There is no GT-R model without full leather. Where is there non leather in your car?
any issues running these directional tyres backwards on a perfectly dry track?
QR is trashing my front left tyre.
I guess I am lazy and dont wont to swap the tyres on the wheels unless I have to.
Mark, we've run a few r-spec tyres backwards in the dry with no problems, to get a bit of extra wear from them. Also, changing topic a bit, with the michelin slicks, i dont believe they are directional (some slicks are) and the porsche guys tell me you can even flip them on the rim (despite there being an outside and inside, the outside merely has a rim protector on it).
Our Toyo 888 test tyres have arrived for the Willall GTR.....let the testing begin :(
Hey Martin, any update on the R888 test?
I hope you are looking after Trent. He has something special coming for my car I believe....
well after 30-33 5 x hot lap sessions at QR, the Toyos looked to be shagged.
with the COBB stage 2 tune I managed a 57.68 on the sprint today on the toyos. I reckon they are at least as good as the Dunlops
will be going out on the track with 18's next time and either second hand michelin slicks or RE55. have the slicks here so not sure if I will buy the RE55's - they aint cheap!
just find a place can order a set of 20" R888 in 285 & 315 $2900 landed Melbourne ( local toyo australia supplier ) few days delivery
is it a bargain?
I am not sure if that is great value or not. I know you can get a set of Bridgestones or Dunlops delivered for less than that. You may wish to consider 285's all round so you can rotate the tyres to prolong their lifespan.
    • don't do. Fricken typos. Make me look like the sheeple.
    • I could show you guys photos of wrap having been removed properly, and where the wrap was removed, paint underneath is perfect. Sections of the vehicle didn't have wrap on it, and in those areas, the paint work is destroyed because of how long it had been sitting in the hot QLD sun for many many many years. Wrap even still looked decent. Good quality wrap, and removing it properly shouldn't rip off the paint work, unless the paintwork was already shot to pieces before hand.
    • Any write ups on replacing the window motor?  I've never messed with them (or window regulators) before.   Ever since I've had the car, the driver window would roll down just fine, but most often I'd have the try a few times to get it to go up.  As soon as it started to go up, it always goes up smoothly and quietly.  Seemed like a bad switch.  But now, its stuck in the fully down position and won't come back up.  I get =12/-12V coming out of the relay/amp when pressing the switch up/down.  So the switch and amp are working.  Just a bad motor.  I've also applied 12V directly to the motor and nada.   Any help on replacing the motor?  Can the glass and regulator stay in, and only replace the motor?  Or not possible?  Thanks!!!
    • You are wrong. That's just Whiteline going along with the incorrect slanguage of the sheeple userbase. They are only correctly known as anti-roll bars. They are only incorrectly known as swaybars. They do do anything to prevent "sway". The swaybars that are fitted to trailler hitches do prevent sway. In the trailer. And they do not look like anti-roll bars. So, take your incorrect infopinion away.
