Diy - Gtr Injector Replacement
MrStabby
Replacing just the seals or the entire injector set is quite an easy job. This work was done on an R32, but since the RB26 didnt change much over its lifetime the 33/34s are hopefully the same. All RB26s use the same injectors.
Note that if you change to a different injector size you MUST have programmable engine management.
WARNING: You will spill fuel during this work. I suggest you;
- Make sure there's no flames or sparks nearby, so no smoking (duh)
- Work on a cold motor
- Have a powder or foam fire extinguisher handy, and make sure you know how to use it (eg if there is a fire, first stop the fuel source, so dont forget to turn off the ignition to stop the fuel pump, then aim the extinguisher at the base of the fire - dont waste it by pushing the flames around). A hose can be dangerous in a fuel fire...
1. The day before you intend to do the work, thoroughly degrease and clean around the injectors.
2. Locate the fuel pump fuse, start the motor then pull the fuse. This will relieve the fuel rail pressure
3. Remove the strut brace and cam breather hose
4. Remove the three 5mm hex key bolts from the black plastic injector wiring cover (just for a bit more flexibility)
5. Disconnect TPS connector and the connector next to make some space
6. Remove the two bolts holding the fuel rail on, then gradually ease the fuel rail up and out. The injectors will probably come with the rail. You dont need to remove the fuel connections to the rail (which are tight)
7. Ease the injectors out one at a time and try to catch any fuel with a rag. If replacing seals, remove the o ring from the top of injector and the rubber mount from the bottom of the injector or the cylinder head if it didnt come out with the injector. I used a watchmakers screwdriver to remove the o ring. If replacing injectors remove the metal clip from the electrical fitting, swap the injector and replace the clip. The outside of the o rings should be smeared with a little rubber grease.
8. Once all the seals or injectors are done, mount the bottom of the injectors then line up the tops of the injectors with the rail and ease it on. Carefully press the rail onto the injectors. Install the rail mounting bolts finger tight then do them up evenly a few turns at a time each side so the rail isnt skewed as it goes on
9. Clean up any spilt fuel. Really. You'll start the motor soon and probably don't want to see it on fire.
10. Replace the wiring connectors, hex bolts and cam breather hose.
11. If you are installing injectors of a different size you need to update your ECU to cope with them.
- If using Nistune; turn the ignition on, load the config from the ECU, save a copy of the config to disk. Select 'Operations -> Resize Injectors'. Enter the original injector size and the new injector size. If the current injectors are OEM you can pull the size in with the 'Factory CC' button. If the new injectors have a different latency to the old ones, use 'Injector Latency -> Change Constant' to make the correction. Apply the new config to the ECU and save the new config to disk using a different filename.
- If using PFC; refer to: http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#57
FWIW OEM GTR injectors have a latency of 770 micro seconds.
12. Start the motor, and watch for any fuel leaks. As the engine is cold it will be running open loop so if it doesnt idle well it probably means the injector re-sizing needs a tweak. Putting a smaller cc number or larger latency number in the resize option will make things run richer, and vice verca. For Nistune if you are changing the cc number remember to use the last figure you entered in the Current field - not the factory number. If you dont understand how cc and latency settings effects fuel delivery in different ways take it to a tuner.
13. Go for a short drive and re-check for fuel leaks
14. If you changed injectors verify AFRs are good with a wideband o2 sensor (all dynos have them). Light load driving is fine in the short term, as closed loop should compensate when the engines warm.
15. Reinstall strut brace and you're done!
  • 4 months later...
  • 3 years later...
You will need the correct length 14mm injector with a 10.2mm adapter. If you try and fit injectors that are too long or short you will need to modify the rail spacers accordingly.
Also, the lower 14mm Oring needs to be replaced with a larger square section Oring.
    • I run 2 x 525 pumps on factory 8mm fuel lines     ... zero issues, staged of course    Your setup should work fine, all you need to do is find the restriction. A good aftermarket fuel regulator is always a good idea too. If it's not your regulator i'd be suspicious of your fuel tank breather and your tank pressurising. Next would be something with the fuel hat. Then blow out the fuel lines.
    • Update time...... Been a crazy busy time and a bit of a change here. Sold my 370z Nismo as wasn't using it much and wanting a 86/brz so wife can have some fun at the track again also to help with funding the s15 build.  As said last time booked a cruise to NZ. The place is great, drank lots of craft beer, eat food and visited some amazing places   The plains of rohan Before we left I finally got an electrician booked and the shed now has power. Been so good being able to use it at night and not running things off a 20m extension lead. Got stuck in last weekend and reorganised it and cleaned up a lot of stuff. A few more things to tidy over time but really good to work on now. There's 13x 10a GPO, 3x 15a GPO, 4 high bay lights and 5 LED batons so will never have an issue seeing or powering tools. 437344198_7178721088892834_15829362501196293_n.mp4   Work has restarted on the s15. Removed the rear cradle so could pull the fuel tank and finish emptying the stale e85 thats now been sitting for almost 4 years 🤮 Cleaned it out and let it dry. Removed the old lift pump and have reinstalled a new lower pressure pierburg pump with all new hose and lowered the pump to get it nice and low in the sump of the tank. Also got a an old diff cover cleaned up, work has a soda blaster so made quick work of it. Going to put a 4.11 ratio diff in with a fresh rebuild thats been reshimmed for now before buying a good diff centre. And had a big change with going back to full time work. Opportunity came up to apply for a race mechanic job so applied and got it, been some big days so far but definitely enjoying it and getting to work on some cool stuff and with some great equipment. Learning a lot on proper car setup and suspension so will be valuable for the s15. I'll be part of the travelling team form next round too. This weekend will get the fuel tank and system in, need to buy a rollover valve and mount that. Get cradle in with the diff and axles then make a shopping list to buy to finish that off then start looking at cooling setup and plan intercooler pipe routing. Work will definitely be slow now on the car but will be to a higher standard.  The 180sx hasn't sold so may be heading out to Morgan Park labour day weekend for a charity event to have some fun been almost 6 months since I've driven it so will be take time to get comfortable again.
    • I'll rent a fuel pressure tester soon and report back.
    • It has a separate fused 10ga wire running from the battery to the relay in the trunk. 10ga on the ground also.
    • Actually I did the fuel pump rewire 2 days after the issues started. Grinded away the paint and grounded it to the chassis behind the right panel in the trunk.
