Holset Hx35w Installation In Standard Low Mount Position
I think the question is, with a R33 GTR, using the alignment settings that that Sydneykid posted.... ....what wheels will fit in the guards without scrubbing with those settings for camber/caster. I do not know the answer to this.
Spray carby cleaner around all gaskets and other possible vac leak locations on the inlet manifold. See if the revs change somewhere. If so, vac leak found. Plug in Consult and see what the ECU says it is doing to the IACV. It will tell you how many "steps" it is commanding it to open. If it is not commanding it to open more than normal, then the problem is elsewhere. If the ECU is trying to drive the IACV really far open, then you know that it is either ECU cray cray or some input to it telling ti be stupid.
