Ballarat Skyline Owners
abacusnow
Just wanting to know how many Ballarat skyline owners are on the forums. I spot quite a few skylines during my day and have never met the owners of the majority. Post a pic of your car and whatever else you feel like sharing.
Do any of the SAUVIC members often visit Ballarat for a cruise up the Highway? Who have you spotted?
  • Replies 104
  • 2 months later...
Yeah i work with Cass at IBM some of the time :(
We've got 3 Skylines there as far as i know.. and one 180.
ghettoracer: i think i saw you the other day.
We should try and arrange for a meet, check out the cars and swap some stories about mechanics! (i know my mechanic reads this forum, so his labor costs might come down strangely..)
used to always go past the IBM centre when i used to visit my grandparents in Grenvale
if thats the one? you turn off before you actual get into Ballarat when your coming from Melb?
i was born in ballarat. gonna be making a day trip down there in there not this week but possible next week or weekend. hopefully may see sum skylines
- Yeah thats the one. On the Corner. I'm also at the mine... Ballarat Goldfields a lot.
I'm on the way to Ballarat from Melbourne, Melton. Who is your mechanic in Ballarat?
- I go to Peter from Performance and Race tech in Delacombe. lots of experience building up cars. he usually has about 5 or 6 skylines in the garage at any one time :down: lol
Another Ballarat lad here.
I see numerous Skylines around town, unfortunately they all seem to be driven by heroes who think they need to drive like a dickhead when they see another Skyline driving past.
LOL!
What's taking Cass so long to get to this thread?
I use to live in Ballarat too.
Because Cas regularly gets busted on SAU at said work, and my bosses don't like it :)
HI ROB
You arent at work much anymore.
This upsets me.
Yeah i work with Cass at IBM some of the time :)
4 actually....the black 32 GTSt with fat ass wheels (p plater), yours, mine, and that redd 33 that parks there every 6 months or so. the one with the half assed spoiler and all the tuner stickers on the doors. 1 180, 1 FTO *cough* ummm...couple 300ZXes.
    • Never cheap out on brakes, tyres, suspension. I learnt the hard way at Oran Park lol
