That above is a ATR43SSG4 core, so similar what it originally was.
The VNT system do work and I've been using them a while now for anti lag. This specific method has the potential to knock off about 500RPMs of lag without trading off power. How ever has to be very specific to the amount of back pressure the turbine housing is receiving. Little like setting up Ign timing which at specific point they will allow the engine to output its highest torque while otherwise results the opposite. Some thing worked so well on the RB25det worked horribly on the Kia's High comp G4GC motor. So getting this to work on the Rb30det it will require a new round of research and development.
Posting an result. This is from a SS2 Based High flow that we did for a Auto M35 stagea not too long ago. It made 275rwkws on 20psi with Pump 98 fuel.
Note: The WOT was engaged in a slow manner on run below, for the reliability of factory Auto.
That pic raises another question Tao , is the compressor housing on your turbo a 0.70 AR T04B one ? The larger ratio B housing is one we don't see too often though I don't know why . It would have a bit more flow capacity than the 0.60AR B housing while being more compact than the T04E or T04S ones .
0.70AR B housings have larger 2.5" (63mm) outlets like 0.70 AR S ones .
A .
And any one into Nissan patrol 4.2L Diesels ? High flowed stock turbo made 121awkws on 15psi maxing out stock fuel pump. Stock turbocharger maxed at 81awkws.
WTF happened to that compressor wheel? What highflow was that?
It is a Kinugawa highflow. The oil feed line let go while coming onto the highway in second at high revs.
Hoookay
Some initial feedback on the TD06SL220.5G
My car is hardly sorted atm
but is as follows
Dead Standard 1JZ-GTE and Auto
ETM 6 into 1 merge collector manifold
Hypergear 50mm External gate
3" dump pipe into a 2 1/4" mid pipe into a 2 1/4" twin system (yuck!)
factory ECU
So initial drive
Builds boost at around the same RPM as the standard turbos...but feels like it needs a little more throttle to do so
Once it sees around 0.2bar and 3000ish rpm it comes on like a light switch even at under half throttle (no WOT runs re: standard ECU) running the 0.8Bar gate pressure
This combo is going to have a monster mid range once I finish the new exhaust (3.5" with a Hooker super comp aero chamber muffler) and fit the ECU and fuel system
but I feel it is not going to be linear, feels like it will always be a light switch turbo, but comes on early enough to not be a huge worry, however I will report back once its tuned and I drive it in the wet.
    • He didn’t provide that info to me but I think I’m on standard timing. And no we don’t have e85 on the petrol stations here but it’s widely available here from shops. I’m just planning on getting a better ecu before switching to e85
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
