Stao does that then mean the water lines etc will line up perfectly or will they be the same as my current SS1PU.
I had a huge headache with the r33 organising the oil return and the water lines when fitting it so I thought if I stuck with the stock setup for the R34 then I wouldn't have that issue again.
The SS1PU has the smaller bearing housing. So they are same the as earlier version.
G2/SS2 and larger versions runs the larger T3x bearing housing. Those are easier to install. Best to have a look at the installation walk through for both in page 1.
Can reuse factory compressor end, not the turbine end. Which gives it a factory look.
Birds. For the drags you will need some 275 MTs, run them at 18psi, and worm them up nicely. If the launch is perfect then a good time is more promising.
One thing I didn't like about Heathcote is how they washes rubber residuals at the start of runway with water every time a car lunches. So we always taking off on wet tires.
They do that at all drag strips, just go around it...
Can anyone with an SS1PU and a Z32 AFM please check their peak AFM voltage on WOT (preferably 3rd of 4th gear) ??
Stao if you can ask Trent for this that would be great also.
Thanks,
I'm running the 275 on 9.5 inches wheels in 17 inches. You can get them to fit.
By the way, I've found a local company whom's happy to produce the braided oil lines at a much cheaper price. as well as the quantity that we are producing. I'm happy to deduce $100 off all High flow jobs as we as none special priced listed items.
Means your high flow job is now $860, and SS1PU/SS2 is $1350 all including oil lines.
Also we are a little over stocked with our billet SS2.5's parts. Now offering cheap for $850 each complete turbocharger with oil line.
C'mon Stao you're killing me, having bought a regular price SS2 just last week ;)
Great prices people, get on em!
Thanks,
No members with an SS1PU want to help out a member who does his best to help everyone he can? :(
I don't have a multimeter sorry mate
If you have a powerFC it will show on the handjob (hand commander), or it will show if you have the software for a nistune if thats what you run.
If anyone has access to either of the above with the same turbo please let me know what reading they are getting at WOT in higher gears :) peak reading.
Birds don't you run a PFC with your SS1PU?
Lol awesome, that's hilarious :)
Good luck for the weekend, will be interesting to see!
Yes indeed, in fact all the guys at tires joint were beating wither this is car has an intercooler or an oversized radiator. I just made 1 person $100 richer today, no one thought this is a turbocharged kia. Ended up with some 225 / 65 / 16 Nitto tires. Still wheel spinning and torque steer all over the places. MT don't make any tires in this size.
How ever this result might give a little indication of what the SS1.5 would do on a SR20det motor, knowing the .64 might be a little chockish, this is running a .86 FNT rear with a 66mm compressor. We were been able to add an additional 5 degrees of timing compare to what it was in the .64 rear. Because the additional timing down low and up top, we ended up picking up 40kws with out getting additional lag.
At about 20psi this turbo would be an idle turbocharger for a SR, with similar response to a Disco.
    • Forgot to add, that excellent economy was on street tyres, normal street alignment, I recall they were Kumho KU31. Current motor, with the silly alignment and tyres would go nowhere near those numbers.
    • And also, as small as the effect may be, the larger exhaust side places a lower restriction on the exhaust flow, even when off boost. When my bigger turbo went on you could hear the difference in the exhaust note at cruise (almost everywhere actually) and fuel consumption went down a little bit.
    • I got better economy after fitting a bigger turbo (when purely highway driving, Sydney to Forster, got down to ~8.3L/100KM), as it takes more throttle and RPM to get on boost.
    • Oops. Sorry mate. It is both excellent to hear and also surprising though. The amount of work required to (effectively manually, not on a production line) build a core vs your low retail price point is why I presumed that you were buying cores. But let's also be clear about what is meant by "build". At your price point I can't see you making cores from billet on a mill, even if CNC, or doing all the machine work on a rough casting. Surely the lumps of metal are sourced more or less ready to go from an Asian supplier, right? Maybe the same with shafts. I mean, you could turn shafts up yourself, but it's pretty slow going for items that are all essentially bulk order producable. I was always perfectly willing to believe that you assemble your wheels to shafts, fit up bearings and do all the balancing. I actually expected that you would have been doing all that even if the core did arrive from a supplier with most of that pre-assembled. Nevertheless, please accept my apology.
    • I hate to interrupt, there are enough internet rumors. I do build every single CORE in house that leaves my workshop including the one that you are using, as well as engineering work done on your turbo housings.  Reason been is I got shafted badly by a turbo joint 18 years ago when the business first started. I since trusted no one when comes to selling anything under my name, or I just don't touch them at all.
