Stao can I also confirm if this ss2 is the same spec as mine?
Also what was done to hold the boost so well? Mine was at 20psi but went down to 16psi at redline?
Trent Im trying to book a tune with your for next Monday :D
Sure I can come to see how it performs. Unfortunately yours is an earlier version. I can upgrade it for a small fee.
you will need to preload the actautor to about 10~15mms from base, which can also hold boost fine.
Thanks Stao
But unfortunately already spend a few hundred getting the rear housing heat coated :(
Wow that is what I call A Grade service!
That would be great! Though it seems like a pain in the ass to change the turbo again :/
Is there a page link to the differences? Much of a muchness?
Haven't been able to read the last 150 pages of this thread yet :/
My old ss2 seems to be doing ok just cant hold boost.
This was 20psi bleeding down to just under 16psi. Or does the revised compressor hold boost better?
Hoping to pump 23/24 psi and hold it as much as possible with the Tune with Trent next week
Look at the torque difference at 3k between your SS2 and the latest one.
You'd expect the Neo engine to produce a little more response anyway...I'd think? That latest run is an S2 R33.
That car had a bell mouth dump with a hi-flow cat. On the standard manifold, I was impressed.
Though the tune was on United P100, not 98. But still far from E85.
So, finally home from the drags. Had a ball.
Unfortunately was unable to get a clean run without at least 1 pop for boost cut, but its OK. I managed to get it pretty good by the 3rd run with only a minor cut just before I crossed the line.
Final run got my PB and was running 11psi (234rwkw @ 20psi when tuned on 45 degree day), creeping a little after 5500rpm. Lots of wheel spin as they auto greened the lights (no stage), plus it felt like my shimmed diff was pegging on the last run also.
Managed 13.0 @ 115mph. I'm pretty happy with this. The car has an easy late 12 in it AS IS and HEAPS more in reserve once I give it back its missing 20psi.
I am happy to report the turbo is AWESOME and the star of my show. Love my SS1PU. I don't think I will want to go VNT, it is balls out enough as it is. Just want to finish my tune once I am done putting run in KMs on the motor :)
Slips attached.
Congratulations. Not bad for street tyres. Need a set of Mickey Thompson ET street. It knocks about 1.3 secs off.
Factory diff was a problem. Mine was doing single wheel spin at launch.
I've bought a set of tomei pon cams and a two way Kaaz diff to be installed. Hopefully be seeing better results.
For my first two runs I honestly had no issues with traction, it was great.
If I got the launch off my first pass which was a 14.x but did not get boost cut and snatched the gears the way I did on my 13s pass I think it would have been late 12s for sure. At least 12.8.
The tyres help up awesome, that's for sure. Can't wait to go again.
Not sure what to do about boost control though. Is it possible for me to exchange my IWG housing for one with an EWG port off the side?
Not bad but you 60ft is average so you ain't launching hard enough but with street tyres the best I could get was a 2.1
I've run a 12.8@116mph and my brother has run a 12.5@116mph
What wrong with you boost control?
Is boost creep common with these turbos? What is your boost cut, as it must be quite bad creep if you were still hitting it with less preload and no external boost control?
Nonetheless, very nice results all things considered - 13.0 @ 115mph isn't bad for your first outing and if you were down on power delivery, definitely more to be had - especially with sticky tyres :) Its a good respectable time which gives you something which is realistic to be aiming or expecting to beat - so till next time! :D
Its actually just AFM voltage cut, so it has no actual PSI value for when it cuts. Unigroup told me it was set to be around 23psi on the day I picked it up, but that was done on a 45deg day as noted. The very next day it was 10 degrees cooler and I couldn't run 18psi without mega cut.
I've been running it off the can all this time which was 13psi, but last night it was about 10 degrees out west and it was hitting cut at about 14-15psi. After taking heaps of preload out it will seeing close to 14psi in high RPM 4th gear, but 11 in the first 3 gears.
so no major boost control issues I guess.. I'm sure if the boost cut wasn't there it could easily be overcome with enough preload and some basic boost control. Its more so the settings in the ecu.
How easily I cracked a 13.0 with that wheel spin launch though, definitely had 12.8 in it even with the boost cut lol I would have taken another mm of preload out if they gave us another run. Oh well, until next time!
Hmmm I'm not inclined to believe that there would be sufficient air density difference to make 23psi on a 45 degree day = 14-15psi on a 10 degree day, not that I know how to explain that but it does seem a bit strange.
    • don't do. Fricken typos. Make me look like the sheeple.
    • I could show you guys photos of wrap having been removed properly, and where the wrap was removed, paint underneath is perfect. Sections of the vehicle didn't have wrap on it, and in those areas, the paint work is destroyed because of how long it had been sitting in the hot QLD sun for many many many years. Wrap even still looked decent. Good quality wrap, and removing it properly shouldn't rip off the paint work, unless the paintwork was already shot to pieces before hand.
    • Any write ups on replacing the window motor?  I've never messed with them (or window regulators) before.   Ever since I've had the car, the driver window would roll down just fine, but most often I'd have the try a few times to get it to go up.  As soon as it started to go up, it always goes up smoothly and quietly.  Seemed like a bad switch.  But now, its stuck in the fully down position and won't come back up.  I get =12/-12V coming out of the relay/amp when pressing the switch up/down.  So the switch and amp are working.  Just a bad motor.  I've also applied 12V directly to the motor and nada.   Any help on replacing the motor?  Can the glass and regulator stay in, and only replace the motor?  Or not possible?  Thanks!!!
    • You are wrong. That's just Whiteline going along with the incorrect slanguage of the sheeple userbase. They are only correctly known as anti-roll bars. They are only incorrectly known as swaybars. They do do anything to prevent "sway". The swaybars that are fitted to trailler hitches do prevent sway. In the trailer. And they do not look like anti-roll bars. So, take your incorrect infopinion away.
