Nice work on the strip :-) glad its now proven that the turbos can trap the speed.
now its time for others to revisit their setups and their tuners.
Indeed, those trap speeds are much more like what one would expect from those power levels... for the sake of interest, what kind of blow of valve is this car running?
Well done stao and status - must've been interesting having it try to swap ends in 3rd or 4th on the strip! :P
Can't wait to get this new clutch in and get back to the strip.
What tyres are you going to run next? Some semis?
He's getting axle tramp as said which wouldn't be helping things.
Stao as reference if you aren't running pineapples already you should get onto it asap.
My S14 has pineapples and does not tramp at all, while friends who don't have the pineapples tramp like mofo's.
Tramp is less about pineapples and subframe location issues than it is about damping. I agree, locking the subframe up with better/newer bushes and/or pineapples is a big help and probably a necessity, but I would always look to the rear damper settings/health as my main concern when trying to fix tramp.
GtScott: Would great if you can pass on a link to those pineapples. I will have a look into them.
Been recommended to Mickey Thomson 16inchs drag tyres. Will need to source that and a set of factory rear rims.
I took few video footages in bystander area. Will upload shortly.
I'm thinking what happens if run a 1.06 turbine end on the G3. it should take away all the zappiness down low causing wheel spin while kicking in mid top range while the car's rolling at much higher speed.
