Got Over 400kw Atw?
T04GTR
Should also list what porting has been done, what plenum and FMIC :D
Head has been ported and polished.
Was with stock plenum.... Now has a Nismo on it (will get back after retune)
FMIC is a big one. Not sure on the size... never measured it.
HKS dumps
HKS front pipe (twin 70 into single 80)
Trust MX cat back (i think its only 3.5 inch)
At the moment ,im running 488.9 rwkw on pump fuel with rb 30 /25 combo twin turbo.head was done by advan performance..hks cams greedy intake custom pipe work ,custom twim 3 inch system from turbos back ..still to run some more boost .and race fuel .and play with cam gears
RB26 stock stroke, HKS S3 87mm pistons, 0.5mm O/S valves, HKS Pro L springs, HKS Pro L Cams, moderate porting, HKS GT2835's, custom plenum, Q45 t/b, apexi drag cooler = 411rwkw@ one bar on pump :D
Mods list:
RB20DET - 399.97rwkws. Close enough is good enough
Turbo: TD06-20G
Cams: Custom Std Nissan customised to factory specs (secret)
Boost: 22psi
400rwkw out of a TD06-20G?
On race fuel?
