N1 Oil Cooler
NISMO
Heres some photos to aid with your cooler install, hope it all works out :P
let me know if you need any more help and you can come around and have a look.
just realized i should have re sized them.
Edited by Angus Smart
Andrew,
You are a legend. It's definitely the exact same kit and goes in the exact same place.
The only prob is that I'm missing the bracket you have in the first pic, but lucky it's the simple one so should be able to buy/make one pretty easy.
I see what you mean about the filter location. In the descriptions i found of the kit it does say that the filter goes on the right strut tower but I'm a bit worried about the lines being short. If not it should definitely mount lower down near where the intercooler return pipe goes.
Now for the fun part :-)
Hopefully I'll get a chance to give it a shot this weekend and see how i go.
Thanks again mate, really appreciate it.
Bobby
    • Have you seen the Milwaukee Train Horn? It's a beast! I stumbled upon it while browsing for upgrades. I'm thinking of adding it to my ride for some serious sound. Here's the link if you wanna check it out: https://bosshorn.com/products/milwaukee-train-horn. Anyway, thanks again for sharing your method.
    • Anybody home...? I used to moderate this part of SAU about 20 years ago... hard to beleive it's still around basically unchanged with all the old posts pinned at the top. Amazing to read all those posts again.  If anyone drops by, I'm still in Japan (Nishinomiya, between Osaka and Kobe).  Cheers 🙂
