V Series Gallery
I had a quick look around the forum and I could not see any threads directly related to V Series pictures (nothing in the Gallery Section either). I thought it would be interesting to see what fine examples we have on show?
EDIT by Nismo
Seeing as there was a lot of chat in the other pic threads, I'll sticky this one and make it NO CHAT, PICS ONLY.
All non pic posts will be deleted. PM me if anyone has any concerns.
Bobby
hey Guys!
Dont know if ou guys have seen my other posts.....
i am from HPI magazine.... i am trying to set up a Sydney V35 cruise...for sometime in November....
Let me know if your interested... we are trying to get at least 40 V35's there...
  • 4 weeks later...
Ah finally, I have been waiting for this car to appear on the forums. I have seen this cruising around and know the seller. Its the only Lakeshore Blue sedan I have seen in QLD apart from mine.
Looks almost identical to mine except for the wheels, wing and grill. As far as I'm aware, the only thing aftermarket is the grill, wheels, and stereo. You've also got factory front cameras and also the OEM lip which are rare options.
I suggest you lower it quick smart :P Welcome to the forums!
Here's mine, don't forget to wave if you see me..
    • well, to check fuel pressure all you need is a gauge and a 8mm joiner with a gauge port in the inlet fuel line; if it stalls at idle when hot you can open the bonnet and check pressure at that time; the fuel pump is a potential cause for what you are describing but it could also be wiring to the pump getting hot. You haven't mentioned that the factory fuel flow control on the fuel pump earth is removed. So either way, it is worth running a suitably sized and fused wire from the battery to pin 30 in a new relay in the boot.  Use the ECU trigger wire into the standard fuel relay to pin 86. Earth relay pin 85 and the Fuel Pump negative (nice big wire for the latter too). Run relay pin 86 pin to Fuel Pump +. That will remove multiple possible fuel pump wiring issues in a 30+ year old car
    • I've been running a 525 for years with the standard hat and FPR in the stagea (mine has a 32 gtr fuel rail and stagea and 32 hat and tank setup are the same) without an issue with base fuel pressure. You said when you disconnected the return it is OK, did you do so at the fuel rail or the fuel hat? Either way I'd be looking for blockages or in the case of the tank kinks in the lines downstream Note I did however have an issue with the current required for the 460 melting the fuel hat.
