How To Appeal A Traffic Infringement?
baby34
I was in the car with my brother, we went to the bank.. I got back in the car he was going to drop me off next block so i didnt put my seatbelt on.. And cop pulls me over. I tried putting seatbelt on but an undercover saw me without it on, so blah blah, got a $153 fine.. anyway i can get out of it?
Who do i send a letter to get it withdrawn? etc?
Thanks!
See I was walking down the street last night, and this guy got in my way, so I killed him. So they wanna put me in jail for life....anyway I can get out of it?
......I don't think so
Thanks!
Lol you were in the wrong. You will not win an appeal. Pay the fine :(
Is this your first offence mate? If so, there may be a good chance you could get out of it. The only thing I can recommend is to admit you were in the wrong. Write a letter stating that you were in the wrong and that you are genuinely remorseful. I have personally written 4 letters trying to get out of fines, and have had the fines revoked three out of four times. The one time I didn't get out of it was because I didnt blame myself! Give it a try, write an articulate and remorseful letter and you may be surprised.
Good luck.
Just try writing a letter bro and u shd be able to get out without paying anything. I have lot of fnds who got parking and speeding fines and they all wrote letters indicating it was their first fault n they ll do everything possible to make sure it does not happen again. n guess wat, they all got their notices cancelled. urs is nt as serious a crime as theirs so just write a letter along those lines n u everything shd b cool.
why appeal?
your in wrong, you said it yourself, cop the fine and be over with it
wether it was a block to drive or 10 blocks down the road you didnt have seatbelt and they caught you without it
this will just teach you to make sure no matter how far you travel to always wear your seatbelt..... expensive lesson huh?
blah blah blah blah blah... SEE ABOVE.. I won't waste time writing any more..as a matter of fact I don't know why I wrote at all :rofl:
but if you do contested it and get off let me know.. Ill write a letter to contest my epa notice for littering stating it was my first time, then write a letter to the court telling them it was my first time I got caught doing 130 in a 70 zone, and then to top it off I'll write one to the lovely undercover officer that fined me for drinking in a public place the other night and see if I can get off too :domokun:
but naa seriously if you were in the wrong why contest it..of all the fines I've had and I can say i've had a few the only one I have ever contested if the speeding one mentioned above because I believe the officers were wrong..and its cost me 3k to date but ill fight it out of principal..
you were in the wrong pay up...its $150 thats like a days wage or one less tank of fuel for the week...or maybe your brother who was stupid enough to let you be a passanger without a seatbelt on should pay it.. I know everyone talks about taking responsibility for yourself..but just like i take responibility and dont do stupid shit with passangers in the car, I also feel I have a duty of care when using my vehicle to ensure all occupants are protected as best as possible..which includes ensuring seatbels are on before I drive anywhere..whether the passanger is 5 or 55..
Edited by zorb_rules
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
    • I was able to complete installation of the G4X ecu. I needed to reroute MAP vacuum signal from stock location to where BOV is connected on the intake plenum. Has anyone needed to do the same? When I connect vac port by the BOV flange to my HKS BOV, it doesnt work and I get flutter. I would to get BOV working, where would it be best to T in? Or would it best for me to move MAP vac line and T into FPR? Secondly, I installed a MAC 3 port boost solenoid and wanted to know if i routed it correctly. I place two lines from stock boost solenoid and placed it on ports 1 and 2, leaving 3 vented. The T for wastegate and boost source on compressor elbow is on port 2, and port 1 is connected to turbo inlet intake pipe. Please see attached pictures. Ill upload ecu config later today. Thanks in advance.
