Bonnet Strut Part Numbers
SSStagea
Anyone know the Nissan Part Numbers for the Bonnet Struts on a Series 2 RS Four S. My local Nissan spare parts doesn't even register the Stagea. I have tried giving them the part numbers that I can find on the current bonnet struts but they come up with nothing. My bonnet will not stay up by itself now, so I am in need of either regassing these struts or buying new.
Thanks
David
  • 5 years later...
They appear to be both the same Stooge, '94 ~ 99 (A32) series.
You could do what I did;
Drive to Strut fitting place, find service guy, have cup of coffee, pay money (maybe $80) & leave. The struts I was sold were Maxima jobs according to my man.
I posted the part numbers here somewhere a few years ago admittedly but can't find post now. (See sig., it's a personal problem :wub: )
The service guy will run a tape measure over the originals for length of stroke & read off/work out the newton metres force (gas charge x piston D/d or something), swap over the original clips & you are done. That's for the fronts, bonnet. The boot lid struts were more of a challenge, I had to get them from Sons of Nippon.
Or maybe;
The nice Strut Specialist service guy might just ID your original struts for you so you can go buy them somewhere else cheaper?
My 2c
GW
I bought some maxi ones from ebay last week these ones:
http://www.ebay.com.au/itm/NISSAN-MAXIMA-BONNET-GAS-STRUTS-NEW-/231052942015?pt=AU_Car_Parts_Accessories&hash=item35cbd41abf&_uhb=1
fitted perfectly and work perfectly almost identical except for the plastic casings on the end.
sweet, thanks for that
might grab those ones, as it looks like they have the metal ends on them, whereas the others i listed above don't
cheers mate
I needed to get the Cima boot redone this morning so I got a mobile guy out to regas them.
He quoted $99 front or rear to replace or regas the stagea ones as well.
So if you need fronts, go to ebay, if you need rears in Sydney
Edward Sing
Gas Strut recharge
0418 807 658
Edward Sing
Gas Strut recharge
0418 807 658
perfect, thanks mate
    • Now as I understand it the engine numbers are sequential for the rb26.  EG stamped - RB26040100A is a 40,100 engine.    Now they made between 1988 and 1994 43,834 R32 GTR's  In 1994 they made 7,464 r32 gtr's.  So if you have a ~37,000++ number RB26 it's "safe" ish to assume its an 1994 motor and a long nose crank ?    The long nose crank being introduced somewhere in Feb of 1993.
    • Try Christian from ITSROM. He should be able to help with a modified ECU. Itsrom | Facebook   or you can send him an email on itsrom AT outlook.com
