Is Gt Wing Illegal
zippy
hi, does anyone know that is it illegal to install the gt wing on the car?
coz im deciding to bid one on ebay.
Edited by zippy
hbahhha not if you got 100000000 hp its good for downforce but yeah as michael says if it doesn't stick out hte sides of the car its not illegal :) i had a twin blade one was inside of the car body but the cops still yellowed me :) so i took it off they said it might cut someones arm off etc tc but yeah if u wanan be picked on by police all the time then yeah put the T wing on :)
Yes, it's illegal. The Style-Police will be knocking on your door in no time with a "Oversized wing" Infringement notice :D:(
asked the pits about it, they said has to be within the body of your car and cant have any sharp edges. no thinner then your thumb they told me
Yes, it's illegal. The Style-Police will be knocking on your door in no time with a "Oversized wing" Infringement notice :) :)
ask paul - i think there was a total of something like 6 lickies for his gt wing :(
A "GT" wing will attract the WRONG attention......
and will attract a defect notice.....
Wings need alot of speed to create downforce......
Where are you going to do that legally on WA roads? And there really isn't an track in WA that could fully utilize wing downforce.....
Use the money for something more useful for your ride. :D
    • Great for thrashing on the track - particularly if it is all corners. Otherwise, it is a recipe for massive tyre wear and reduced straight line traction. -1 is plenty for a streeter.
    • There are other MAP tapping ports. There's one that runs to the boost gauge MAP sensor on the firewall (over in the corner behind the brake booster). Start at that sensor and follow the hose to the plenum.
    • Japanese circuits have always looked tight to me on Youtube vids. They seem to be able to fit tracks into the smallest of spots. I've never experimented with camber in the rear. I'm running similar front camber to you (albeit in the E90) but I've been looking into what options I have in the rear. -3 rear seems like a lot. Yeah, mine is the N54. I had an N52 330i for about 7 years, it was awesome but I just needed a little more poke. The N54 is also DI. I'm running BC coilovers with the M3 front arms and a Whiteline front sway bar and the turn in and ride quality is brilliant. But I do still suffer from a bit of roll so I've been looking into that lately.
    • Thank you for explaining. Makes more sense now. I saw that diagram but wasnt sure if the MAC solenoid would use the same plumbing. So I just did what the stock looked like. Ill get that fixed. I even saw this image As for MAP sensor, When I place vacuum line from MAP to stock location vac reference ( port by BOV flange ) the car runs like crap. I think the port is clogged or something, cause when I moved the MAP line to plenum and connected the BOV to that line, I get compressor surge. This is why I moved MAP vacuum line to plenum where BOV is. Where can I T the MAP vacuum? Sources Ive read said to let MAP vacuum be its own and not to T.
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
