Who's Got The Best Looking N/a Here?
Guest IH8VEE8S
  • 2 months later...
  • 3 months later...
  • 4 months later...
This is mine
Exterior:
Genuine Jun rear pods
400r skirts
Genuine gtr wing
Sedan. Indicators and grill
Can't remember front lip
Engine:
Genuine ARC airbox (made for gtst)
D1 Spec catch can
Cusco strut bar ( was old so rattle canned red )
4 coil aluminium radiator
And other bits
Wheels and Suspension
Random China tyres
Xxr 531 (17x10 +20 )
Bc BL coil overs ( gold plate )
Cusco upper camber arms ( yet to be installed )
  • 2 months later...
    • I've been running a 525 for years with the standard hat and FPR in the stagea (mine has a 32 gtr fuel rail and stagea and 32 hat and tank setup are the same) without an issue with base fuel pressure. You said when you disconnected the return it is OK, did you do so at the fuel rail or the fuel hat? Either way I'd be looking for blockages or in the case of the tank kinks in the lines downstream Note I did however have an issue with the current required for the 460 melting the fuel hat.
