What Spark Plugs For Rb25det?
28 replies to this topic
    Rank: RB20DET
  • Gender:Male
  • Interests:Spending money on my car.
  • Car(s):R32 Nissan Skyline
  • Real Name:Jarrod Goulter
I was just down at my local Supercheap to grab a six pack of plugs for my girl and apart from them not having any guide on Imports and the Bosch site on the net being useless, I am lost.
I have NGK Iridium "BCPR6EIX-11" in at the moment but I want to get the new Bosch Fusion plugs.
I think I need F1-6 but I am unsure especially sine they are $129 for the six.
It is for an RB25DET out of an R33.
Cheers guys
Posted 06 April 2008 - 12:54 PM
    S2-R33
  • Gender:Male
  • Car(s):JZX100
I run NGK BCPR6ES in RB25's gaped at 0.8 mm
NGK BCPR6ES come in 1.1 mm gap (BCPR6ES 11) and in 0.8 mm gap (BCPR6ES 8)
Standard boost = BCPR6ES 11
12 psi = BCPR6ES 8
Up to 19 psi = BCPR7ES 8
Over 19 psi = BCPR7ES 6
^ Hope this helps
Posted 06 April 2008 - 02:41 PM
R33 S2, 200kw - SOLD :(
JZX100 - 1JZ BABY!!
www.sidd-rishi.com.au
Need a wedding photographer?? Check out my website :)
    Rank: RB20DET
  • Gender:Male
I think the wrong plugs have rooted my coil packs.
I changed the plugs and not two weeks later I need two new coil packs.
I actually have an RB25det Neo motor and I am wondering what plugs to put in it?
I have Splitfire coil packs coming in a week and I will be running 10Psi.
Cheers,
Jarrod
Posted 02 May 2008 - 04:19 PM
    driftin_out
  • Gender:Male
  • Car(s):'96 R33 GTS-T Skyline
  • Real Name:David
yo siddr20....
use bkr6eya-11 there still $3 a plug...
or bcp6rya-11 if u can get those ones..
ther anti-fouling plugs..lol
hence the "ya"!!!
:nyaanyaa:
anyone try using denso plugs?????
which is the standard plugs in Toyota..
i've used iridiums.. bkr6eya-ix
didnt do much of difference..just cost more...
ur better off just buying standard plugs...
Posted 04 May 2008 - 10:50 PM
"You could feel Godzilla was there......inside......dozing......"
"God made lag to give V8's a chance!!!"
  • Real Name:chris
IF i had a dual stage boost controler set at 7 & 12psi with splitfires. Would you recomend 0.8 or 1.1 gapping?
Posted 05 May 2008 - 07:25 PM
    Does this make my ass look big?
  • Gender:Male
  • Car(s):R33 GTST
  • Real Name:Tony
run the biggest gap you can get away with. if the spark breaks down (misfiring), you know you need to gap them lower. so 1.1mm is great if you have no issues. if not go down to 0.8mm. it all depends on how well your coilpacks work.
Posted 05 May 2008 - 07:44 PM
  • Gender:Male
  • Car(s):R33 GTS-T
  • Real Name:john
i have the HKS S40i plugs in mine. they have denso printed on the side of em.
they are great never missed a beat :P
Posted 13 May 2008 - 10:32 PM
  • Gender:Male
  • Car(s):1997 nissan stagea rs4
  • Real Name:shayne
the splitfires i recieved in mail today say it is essential to replace plugs with one colder heat range if you have any type of mod besides splitfires(pods,exhaust,chips etc) and should be resistor types,so of the plugs mentioned in this thread,which would be more suitable?
Posted 07 June 2008 - 12:19 AM
    adj : wanted intensely
  • Craved
  • Moderators
  • 21,752 posts
  • Gender:Male
  • Car(s):R33GTSTx2 +more
  • Real Name:Chris
BCPR7ES 8 or 11
Posted 07 June 2008 - 12:37 AM
Craved Coatings
Custom Powdercoating and now exhaust Ceramic Coatings
  • Interests:cars
  • Car(s):R33 Gtst
I just pulled out my BCP7ES plugs and the tips of the plugs were mainly white, what does that mean?
Runinng 1 bar of boost on a tuned motor....
thnx
Posted 23 November 2009 - 05:43 PM
  • Gender:Male
thinking of getting the NGK BCPR7ES from Kudo with a 0.8 gap
would going one colder then the NGK BCPR6ES be detrimental in anyway ( cant seem to find the NGK BCPR6ES with 0.8 gap anywhere)
Posted 18 November 2012 - 09:48 AM
3inch Turbo back (Gtr cat + gtr front pipe) | Blitz turn flow intercooler | HDI dual stage boost controller + guage |
Pedders Coilovers | 18x235 F 18x 255 rear | Uprated toyota manifold studs | Pod | Slotted rotors + QFM HPX pads
Soon :
Walboro fuel pump | High flow turbo | 550cc injectors | Stage 2 mv automatics shift kit | Tranny cooler
    Rank: RB20DET
  • Car(s):Series 2 R33 GTST
  • Real Name:Jase
Dig dig dig..
Sorry guys thought id dig instead of starting whole new thread.
I am now confused on what plug to use on my stock R33 RB25DET. It has a aftermarket exhaust (3inch i think) Pod, getting a BOV installed and thats it. Boost controller and a FMIC intercooler will be installed and running on 11 or 12psi with standard turbo.
Which one would be best for daily driving if i gap them to .08
BCPR6ES
BCPR7ES
bkr6eya-11
Or if anyone can recommend a good plug thats not $20 a plug that will be great. Cheers
Posted 23 August 2013 - 01:47 PM
    RB25DET
  • Gender:Male
  • Car(s):R34 GTT, CBR600RR
  • Real Name:Charles
BCPR6E will be fine, gapped at 0.8. Copper plugs, $28 for 6 at supercheap or repco
Posted 23 August 2013 - 02:28 PM
    Slap my elbow
  • Gender:Male
  • Interests:I wanna go fast.
  • Car(s):Stagea
  • Real Name:Ben
Dig dig dig..
BCPR6ES
BCPR7ES
bkr6eya-11
you already have a blow of valve. Please don't install a different one. ○_○ ...... Do you understand the difference of the plugs? The higher the number the colder the plug. I don't see a reason why you would need a cooler plug.
Edited by superben, 23 August 2013 - 03:53 PM.
Posted 23 August 2013 - 03:51 PM
    Slap my elbow
  • Gender:Male
  • Car(s):Stagea
  • Real Name:Ben
Oh and the final number is the gap
Posted 23 August 2013 - 03:54 PM
    Rank: RB30E
  • Gender:Male
  • Car(s):R32 GT-R, R31 '89 GXE
  • Real Name:Ravi
BCPR6ES (they should be 0.8mm gapped). If the shop doesn't have it, go somewhere else. If you have a feeler gauge, you can gap them down (stores usually stock BCPR6ES-11, the 1.1mm gapped ones). Run 1.1mm gap (factory) if you have new coilpacks.
Posted 23 August 2013 - 04:57 PM
I have R32 stuff for sale (GT-R suspension, exhaust and such), PM me.
    Rank: RB20DET
  • Real Name:Jase
Ben I have NGK BCPR6ES-11 plugs so its the 1.1mm gap as you know :) I will re gap them to .80mm.
Nizmo so are you saying that I should leave the 1.1mm gap if I'm running factory coils?
Posted 23 August 2013 - 05:44 PM
    Rank: RB20DET
  • Real Name:Jase
Oh and Ben yeah I knew it was a different heat rating but when I was doing some searching there was a thread that people were telling a guy to buy the 7s then I came in this thread and its all different plugs so that's why I got a little confused on what to use
Posted 23 August 2013 - 05:46 PM
    DERP DERP DERP
  • mad082
  • Contributor
  • 37,758 posts
  • Gender:Male
  • Car(s):nuffin
  • Real Name:Hugh Jorgan
If you can run the 1.1mm gap without it missing then do it. The bigger gap the better. People only reduce the gap when they are running large boost or have old, weak coils that can't provide a strong enough spark
Posted 23 August 2013 - 06:08 PM
Alright Stop!!1!ty... Hammer Time
marc's right
You're a proper git.
    Rank: RB20DET
  • Real Name:Jase
That's what I thought.. I will try the 1.1mm gap an see how I go. It only has 140k on the engine so coils might be fine.
Is 1.1mm and 0.8mm the only 2 gaps I can run or should I try lower the gap in 0.1mm increments like as in if 1.1mm doesn't work maybe try 1mm then 0.9 then 0.8 or is that pointless? I'm new to the whole boost scene so excuse my lack of knowledge haha appreciate everyone's help :)
Posted 23 August 2013 - 06:17 PM
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
