JJR Coil Packs Vs Oem Vs Splitfire Vs Other
I've got DBW, easily done via the Haltech. Just need to feed in brake & clutch input however I'm out of inputs. Will need an IC10 dash or I/O expander to get more inputs. -
And what you now need is cruise control for your 'line to get even better economy . . . . or build one to suit . . . . . . . . wait like I did . . . . . . . and never again . . . . . . . . I'd rather snort wasabi ! ! !
The base problem was the turbo actuator arms. I could have just done the turbos but opted to do all supporting hardware at the same time to really future proof the car for me. But yeah, wont be much change from $6k.
You can just swap the pins at the CAS connector side. You could go old school and use a test light to see which pin is going back to B1 on your ECU
