Bmw Boy Two Japan Visits
bmwpaul
Hi all I've been to Japan twice as a stop over on my way to the States. First time in was in July 2004 I spent spent a couple of days with a Canadian BMW guy I meet via the web, and last time was June 2007, just a couple of months back. I stayed just over night at Shinjuku at a hotel recommended via a Japan forum ;)
glad you enjoyed your stay!
The pics leave a little to be desired though..theyre a little blurry.
Edited by m3gtr
