How-to: Greddy-style Plenum Install
309 replies to this topic
  • Gender:Male
  • Interests:Nissans, Turbo's, drifting, building jap cars
  • Car(s):Nissan 200sx s14
  • Real Name:Jordan Telenta
u know how u cut the top feed fuel rail off, did u block it off or route it somewhere else? didnt see in ur guide about that,and i dont really want to read through 12 pages!
Posted 27 January 2011 - 05:04 AM
  • Car(s):skyline r33 gts-t
  • Real Name:trent
Can someone PLEASE help me out... Iv installed a front facing plenum(exactly to tutorial) and a large throttle body...
the car hasnt been started for 3months.
I finished the plenum today and did the coolant. the car idled fine for about 10mins then it just idled extremely low and sounded like shit then started struggling so i turned it off.
I tried to start it again and it made some funny noise and wont kick over and if it does it just idles really low and sounds really bad.
PLEASE help..
Someone told me it could be that the fuel has gone bad.. but it was fine for 10mins.
Posted 13 February 2011 - 04:22 PM
  • Gender:Male
  • Car(s):1991 R32 sedan
  • Real Name:Jonny
Checked for vacuum leaks? Your car will idle a bit higher when you first start it, then once it settles if you have any vacuum leaks they will become apparent as the revs will drop and your car will start 'hunting', i.e revs will drop,drop,drop and then kick back up. Have a good look over EVERYTHING. Even if you havn't changed something you could have knocked a hose off or something equally annoying.
Posted 20 March 2011 - 01:55 PM
Do we need to plug both clips back into the AAC on the new plenum? the tutorial only says to extend the brown plug, so it reaches the AAC unit on the new plenum but the purple plug doesnt? do i just extend the purple clip or dont i need it?? Cheers, Chad
Posted 24 March 2011 - 11:28 AM
Worked it out, runs great! but thanks for everyones help
Posted 30 March 2011 - 07:31 AM
  • Car(s):s13_rb25
  • Real Name:Rick
hey im currently building an rb25 to put in my r32 skyline..just curios in all the pics posted the plenum sits very close to the r33 skylines clucth cylinder on the firwall..
an i know that a r32 skylines clutch cylinder is longer than the r33 one... so i want to know if anyone has fitted an rb25 with a greddy or greddy copy plenum to a r32 skyline and whether it hit the clutch cylider or the clutch line?
thanks
Posted 18 June 2011 - 02:54 PM
  • Gender:Male
thanks
You need to use a R33 clutch master in a R32, mine is fine with clearances after the R33 change over
Posted 20 June 2011 - 11:57 AM
R32 GTR in the build for some track fun!
CLICK HERE FOR THE NEW BUILD THREAD!
  • Gender:Male
  • Interests:cruising
  • Car(s):R33 GTR
  • Real Name:ANTHONY
hey guys got this off guy on here where do all the fuel lines go and the coolant hoses and lines plug in to.. help would be good thanks
Posted 11 October 2011 - 11:32 PM
  • Gender:Male
  • Car(s):1990 A31 Nissan Cefiro
  • Real Name:Chris Filacouridis
hmm just bought a greddy copy plenum and one of my injectors is about 1mm off from one of the holes in the plenum and is stretching the seal a bit when the rail is bolted down.
Fingers crossed i don't get a air leak or i wont be happy.
Some advise. make sure everything fits before you paint your plenum because i dont think ill be able to send mine back now if it leaks.
Posted 29 November 2011 - 05:48 PM
  • Gender:Male
  • Car(s):R34 GT with RB25DET Neo
  • Real Name:Martin
Right, time for this threads yearly revival.
I'm looking into getting one of these plenums for my 34, but I've read through all 13 pages and didn't find any conclusive answers to the differences between the motors. So. Has anyone installed one of these on a Neo? If not then I guess I will have to be a pioneer, but thought I'd ask first.
From what I can tell, the stock TB is out of the question, so I'm going to need an aftermarket one, correct? That's fine, given I've done away with TCS already. Any advice on brand, where to buy from, etc? What else do I need? Gasket, recommended place to buy?
Posted 03 February 2012 - 05:43 PM
Unzipped Composites:
Producing quality carbon fibre/kevlar/fibreglass reinforced composites. See my work here.
10405497_10152080384192541_2536449166530
  • Gender:Male
  • Car(s):R34 Gt+t
  • Real Name:David
Genuine or copy would be my first question.. There are some Jun styled ones on ebay specifically for the 25neo to retain the factory Idle Air Control.
Posted 03 February 2012 - 07:00 PM
          Shell, on 15 Sept 2013 - 18:11, said:
          TAKE IT LIKE A RETARD
Remember, its not about the time you do, but the smoke you make
  • Gender:Male
  • Real Name:Martin
Copy at this stage, more specifically the Autobahn ones because I've seen a lot around that are quite high quality. Unless anyone has any other recommendations? Have you got a link to the Jun style ones, are they decent enough quality?
*EDIT* This one you mean? http://www.ebay.com....0#ht_5173wt_905
For the price I could almost go genuine though...
Edited by Hanaldo, 03 February 2012 - 07:20 PM.
Posted 03 February 2012 - 07:17 PM
  • 89CAL
  • Members
  • PipPipPipPipPipPipPip
  • 5,764 posts
  • Gender:Male
  • Car(s):R33 GTS-t
  • Real Name:Callan
I have an autobarn Greddy Copy. Been on the car for 2 years now, run 18psi through it for the last year without issues. Just spend some time prepping it before install
Posted 04 February 2012 - 07:46 AM
  • Car(s):r33 gtst
  • Real Name:harris
I posted in the forced induction section but only got one reply, if anyone else had similar issue can they share their experience
I purchased my car with a modified std plenum (throttle body cut and welded to the front), as im upgrading to a larger turbo and goin to push around 20psi shortly. I dint want any detonation problems caused by uneven distribution of air between cylinders that the plenum would (probably) cause.So over the long w.e i fited a Chinese GReddy plenum. The previous plenum setup ran perfect with my power fc (tuned for std turbo,injectors,afm,12psi) and even on the std ecu. With the new plenum fitted car fired up first crank,idle was abit rough though expected, when for a drive and there is a masive loss of power. Car is struggling to rev through the range, as if a shit load of timing has been pulled out (similar to R&R) but worse. Do you think it could throw the tune out because of the shorter runners and overall volume change ect of the new plenum, or have i done somthing wrong (followed the wright up in DIY). Like a big vac leak, all looms are pluged in,i used gsket goo between head and plenum but also reused factoty metal gasket. Holds boost fine. Also plugged std ecu back in idles perfect and drove allot better but not 100%.
Sorry for essay. What do you guys think.
Edited by dori33, 04 February 2012 - 08:43 AM.
Posted 04 February 2012 - 08:42 AM
  • 89CAL
  • Members
  • 5,764 posts
  • Gender:Male
  • Car(s):R33 GTS-t
  • Real Name:Callan
You changed something pretty major and didnt get it tuned.. what do you expect?
The standard plenum is designed to recieve air in the centre, the Greddy style plenums are designed to recieve air from the front. This is why its not ideal to mod the standard plenum to front facing.
I'd suggest that your tune is out now because the cylinders are recieving air a bit more evenly. But having said that maybe you just missed something and have a VAC leak or some other issue
But I think a retune will fix alot if your stock computer is running the car O.K
Posted 04 February 2012 - 10:04 AM
  • Gender:Male
  • Real Name:Martin
Yeh from what I can see, the Jun style ones on eBay look pretty high quality as well. Thing is, for $875 delivered, it would only cost $200 more to get a genuine Plazmaman...
Worth it?
Posted 04 February 2012 - 11:26 AM
  • Gender:Male
Worth it?
Don't get a Jun style one, stick with the Freddy!
Posted 04 February 2012 - 01:00 PM
  • Gender:Male
  • Real Name:Martin
Doubt I'm gonna get the Jun style one, can't justify the price compared to the well known brands.
Freddy was the original plan, but they don't make them specifically for 34's... Seems like a lot of farkin around to get them to fit. After a bit of research, I'd also like to keep the standard runners, don't want to lose mid-range.
Posted 04 February 2012 - 01:25 PM
  • Gender:Male
  • Car(s):R34 Gt+t
  • Real Name:David
then plazmaman is your answer, They do sit quite high though which means its a tight fit with the strut brace.. I actually just swapped one over to a Greddy copy one because the owner didnt like it and said he had bonnet closing issues towards the throttle body I think he is wrong but none the less did the job because thats what im paid for..
Reason I suggested the Jun style ones was because you do have a higher initial outlay but u dont have to faff about with the iac from and may work out cheaper in the end..
Posted 04 February 2012 - 08:08 PM
  • Gender:Male
  • Real Name:Martin
Does anyone have experience using the Plazmaman in an R34 engine bay? Only person I know of is muchogarcia, he hasn't replied to a pm yet though.
Posted 04 February 2012 - 08:20 PM
