Z32 Igniton Dwell Duty
Interesting,
Didn't think this topic would surface again.
I had the too many points in my charts before ^^60 not ^^6F, there are only 16 points not 32 thus the rpm scale is in 400 rpm increments.
The divide by 10 to convert to dwell % was gleened for some ecu tuning forum somewhere.
This appears not to be the case thankfully as 25.5% seemed to be max dwell duty % before.
so i guess i need to work out the constant to convert from ecu values in dec to dwell duty %.
will post back later.
  • 2 years later...
Bump.
I know this thread is old, but I'm going to be doing an LS2 coil swap in favour of the garbage RB20 coils I'm running on my RB30.
Can anyone explain the correlation between dwell duty cycle and actual dwell time so i can set them up properly?
Bump.
They are 2 different things. If frequency didn't change then there would a correlation between the 2 but because frequency increases (with RPM), then duty cycle must increase to achieve the same ON time (in milliseconds) in order to reach coil saturation.
The pic shows that duty cycle has to increase as rpm increases, simply because we have less time.
Ah ok... Makes sense. Do you know if i can even adjust actuall dwell to suit other coils then with nistune?
That pic i posted was from nistune. You can adjust it, but if you add too much duty cycle you will just burn out coils.
Millisecond adjustments with nistune are simply to compensate for lower battery voltages. Duty cycle adjustments are for the on time, which will increase as rpm rises.
Easiest way to find out what is required is to hook coil up to a scope, you will see when full saturation is acheived because current will stop climbing and level out.
Otherwise, provided the primary winding are resistances are massively dissimilar, i would just leave them.
Edited by kjb_r33
Thanks a lot man you've been super helpful. The thing is, I'm going from R32 coils to LS2 coils which have a WAY higher spark energy and a significantly different dwell time (I think), I guess I'll just play with it slowly. Heres some interesting data on the coils I'm using: http://www.megamanual.com/seq/coils.htm
Do you know what the "nominal dwell" would be on the stock coils?
Edited by ST240
It actually states on there to use no more than 6 milliseconds. It also states that the millisecond compensation is for dropping battery voltages. (both can be adjusted with nistune).
Id be inclined to get them wired up, then adjust the dwell duty cycle to achieve the 6ms.
This will give you max coil output at a duty cycle thats not going to shorten coil life excessively.
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
