Stagea Fuel Economy
RUS
I have tried the search function and not found what I am after:
My Stagea (1997 Auto RS Four V) is using on average 16.4 litres/100km.
Is this normal?
What are other peoples fuel consumption figures?
Can you link me to any threads that discuss this?
It has to do with the weight of Stageas ~1700kgs, the fact that they share the aerodynamics with a tissue box, and how you use your throttle, and the fact that you have 4wd too.
I had my power-fc tunes for economy and was reeeeealy gentle on the throttle and got 9lts/100kms out of her.
Read this thread:
http://www.skylinesaustralia.com/forums/in...945&hl=fuel
holy crap joe! mine would be lucky to get 300 :blink:
you serious on you car you only get 300km/tank? Im getting 400-450/tank. you better go for a retune buddy it will save you in the long run. if thats the case use boost 98 to cut costs man.
Average 11.7L/100km in town, 9-10L/100km on the highway.
It all comes down to a good tune, and a controlled right foot...
oh, and adelaide traffic isn't as bad as in other states so your results may vary a bit...
but then with better roads like in QLD I averaged <11L/100km when on holiday in brisbane...
300km would be correct, with no safc and with a shagged exhaust temp sensor....
I was on around 320-350kms then replaced the exhaust temp sensor and added an safc and it got 450km (fuel light staying on) with 140awkw.
after a retune soon to suit the different muffler, incl adding on an adj cam gear wheel, should get 190awkw and still be around the 400km per tank mark.
i get 200 KM to the tank in city
around 300 on the highway
man is your foot made out of lead or wat?your car got a serious problem. I think it definetely can guzzle gas quicker than all of us guzzling a pot of cold beer!!!! :rant:
i also changed o2 sensor, and it improved slightly....
but as i said im getting an safc in the next couple of weeks, and i will also try and track down an SITC
who sells this boost98?
united. search for the thread on boost 98. and there a link in there which will tell you where boost 98 is available. its good stuff.
Thanks for the info...
I will try replacing the O2 sensor next week. If that does not help I will install an old SAFC I have lying around.
Say you call "a tank" 50lt to be conservative as 200km is ridiculous anyway you swing it... That's 25lt/100km
What modifications have you got mechanically to achieve such a stupid result? Larger injectors and unburnt fuel running out the exhaust?
I suggest you check the "gas" tank for holes there boy! I'm sure driving "style" is a contributing factor...
Just install the SAFC anyway. I picked up almost 20awkw from that alone. Still waiting on results on Fuel economy. Think it can still be leaned out more on lower throttle
lead footed? or the engine is a real "gas guzzler" like the yankees like to say.
    • I've got some bad news unfortunately.  Turns out the car has some serious chassis damage and failed a structural report, which was needed because of a failed roadworthy.   I'm now sitting here wondering wtf I'm supposed to do with a car that I can't register and needs serious body work. 😓 Seriously feeling lost, ripped off and depressed over this.
    • FYI if interested  Brake rotors got taken down to 389mm for clearance and all things adjusted accordingly #bolton Had a quick retune of the retune to change the VCT window plus some of this and that Took 7 weeks for me to get a barrell of fuel to run my car on the track = W.A Actually attempted to drive this thing on the track after 6 months when this shouldve really been 3 monthly ago Only a few laps - stuff didnt go right because electronic aids in the car mean you drive it a certain way when its indicated they are on and they are actually not things dont go great quickly - car fixed and refreshed + thats been fixed with additional warnings and other thing built in now Noted - even mucking around at prob 60 - 70% the aero was now hitting the ground where it hadnt previously at 100% plus the balance of the car is improved - hence without shock pots etc etc you can tell the new aero additions have done something reasonably significant Suspension out - change the bumps and some packers  Tried to go out again - lightning and thunder storms / rain in Perth for the  first time in 50 years for the hour I had - didnt get out V8SC are now here so no track time at Barbs for many weeks - an going to try go down to our other track a few hours away and try to get in the seat Got the below as a pressie recently - yes I dont mind the odd lego + this is very good I think and if not into lego even can appreciate someones craftmanship of this level
    • ok will do, cheers guys build thread on M35 Stagea Tuner Facebook group here if you can't wait.
    • look up "kota the yota" on youtube he runs an export business to the us and specialises in r34's
    • I understand that the R34 ECU can be sensitive to what is going on wrt the coilpacks/loom. You'd be well advised to put a Consult reader onto the diagnostic port and read the codes. The one(s) in the ECU will be the ones most likely to tell you what's going on. The TCS light will be a secondary effect.
