Roof Rack
66yostagea
Needed a roof rack in a hurry.
Used some 25mm OD pipe, Cyclone scaffold tees, 25mm ID clear plastic tube, black paint and duct tape.
The horizontal section of the tees needed flattening a bit to more nearly be the shape of the rails.Pipe was cut 920 for back, and 945 front. They are different, and the front was cut a bit short so it can be moved back to the centre of the rails. Metal parts were sprayed matt black and the tube was slit along its length to make it easier. Duct tape was wrapped around the hose, and also around rails where tees were clamped.
After using I had to move the front cross piece back to the centre because of wind noise.
Total cost if buying all the bits, about $20.
Edited by 66yostagea
just for interest's sake,toyota rav 4 roof racks are a straight bolt on for stageas. I run a pair of ex-warranty rav racks on my S2.
new from toyota they're about $280 a pair.
Justin...
I used my Subaru Racks, $350. Big difference $20. They do the same thing. lol
it IS a big difference,providing you actually pay it. I got my rav racks for free,out of the warranty bin at clean up time. I have a heap of roof rack parts at home,including some rx330 aero racks. will try those on at some point as well. if they work,someone can have my rav racks if they need a set.
Justin...
Edited by fergo308
Nice work there Hugh! So when are you going to start making them enmasse and sell them on SAu in a group buy for $50? ;)
That is what is the rage lately, I am still trying to find out what I can setup a Group Buy for :cheers:
And damn, you really dont have any sunroofs, bummer :ban:
i can imagine what that will do for your highway fuel consumption. i think i'll be going for a more aerodynamically designed one.
Even with my ex Subaru and Skyline racks I always had to move them back a bit from the front.
As I've said elsewhere, " if you can't afford the petrol,you can't afford a Stagea".
Anyway, racks are not usually an everyday use. The bars take 5 mins to remove. The whole idea was to make something pronto.
As far as agroup buy, The only tools needed are a hacksaw (or angle grinder) to cut the pipe, a 10mm open ender and a Stanley knife, so it is very easy to make. Not really worth the postage.
  • 4 years later...
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
