Jack Stand Points Needed
QRI05E
Hey Guys... im going to attempt to install my FMIC in the upcomming weeks and just QRI05E (curious) :) to know where is the safest part to place my jack stands while working on the car?
Could some one please post up a pic showing where to place them under the car??
um i placed mine just underneath my suspension arms (actual name fails me.. wishbones or something? i duno, independant bits at the front) on the rubber washers just as they join up with the rest of the under carriage. probably the best place to jack as the front as the sills will be a bit to far back for stability and are rather hard to access if youve got a kit.
Edited by r32 gts-turbo
i cant put them under the frame rails due to my trolly jack being too high to fit under the car after lowering it 3" : can anyone please post up a pic??
Edited by QRI05E
i know what u mean...
i have 2 ways of jacking up my car..
1/ piece of wood and bricks, which i drive the front wheels on and put the jack under
2/ get a scissor jack, jack it up from the side enough to get a mini trolley jack in, then get the big trolley jack in the front..
either way its a bitch
Try the frame rails under the floor but put a rag between the rail and stand.This will protect the paint.
Are you talking about the chassis rails? I was under the impressions it is an extremely bad idea to use these are jack points as they tend to bend and buckle.
Thanks for that John, ill use those methods next time...
Using this diagram could some one please circle where the safest points are to place the jack stands?
I recall reading something somehere (either SDU or one of the UK forums) about a similar topic.. there's a nissan made part specifically for jack stands and skylines. I did add the item to my post skyline purchase shopping list (nissan part# LM450-60000), but don't know how much, or if they're available here.
i use the points that ive circled below.. not sure what its called.. can someone tell me if its alrght to use them ??? im also curious where the correct place to put the jack is... i always get realy paranoid the car is gonna fall ;)
between the two circles is the front cross member/subframe, that is a good place to use. Be careful since the sump is a bad place to use. there is also the tow hooks at the front they are great jacking points.
also be very careful if you are putting the jack under the side of the front subframe, the lower control arm is not safe - it moves relative to the chasis when you jack the car up.
chasis rails are OK to put stands under *if* you use the thicker area towards the front and let the car down slowly. even better if you have to do this use a piece of wood on top of the chasis stand along the rail to spread the weight.
at the rear, like the pic says, use the diff or rear subframe.
the sils are a no no they wil crush for sure unless you are using the nissan scissor jack or a hoist with rubber pads (and sometimes even then)
    • What's wrong with the OEM filter. They do the job perfectly. As to your actual problems. Stop driving the. Take it to a mechanic. If you actually do have a fuel delivery limitation and you are putting it under load, you could be killing it.
    • Enjoy Japan!  Need someone to carry your bags........??
    • I don't know the answer, but my uneducated guess is this will not work (or, not as you want it to). I would wire the SLD into VSS1, I bet that is what the limiter uses However, I also bet the ECU compares VSS1 and VSS2 and throws and error if they are different. Best suggestion I can make is wire it into VSS1 and see how you go, I guess the error will only appear above 180 when then SLD is active. If it appears at lower speeds put a switch into the SLD earth (or power supply) and only turn it on when you need to go over 180.
    • Hi all, So, looking to do some general maintenance on the car, as it has developed a some slight (related?) problems; Three problems that I think are related. 1999 R34 GTR RB26 - engine will sometimes cut out while left on idle, but will keep going if I keep throttle input. Usually after having driven a while. Its random, somedays wont happen at all, others will happen once or twice in a half hour drive. - Second issue is that while driving, the car will sometimes not be able to get past 3k rpm, no matter how much throttle input I apply. - Lastly, car will sometimes be real laggy climbing through rpm, but if I apply lots of throttle problem will seem to clear and go back to normal. All issues come and go, again somedays no sign of any problem, other days will just be stuttering around for ages.   I think it might be either the fuel system, or maybe the AFM?   Either way, I am going to clean the AFMs, and replace the fuel filter, use some injector cleaner in the next few fill ups, and might look at doing the fuel pump aswell.   Question I have, is filter such as; https://www.efisolutions.com.au/pro-fuel-filter-30-micron-an8-orb-black Fine to replace the normal filter? Their product page says as a prefilter only and not as the main EFI filter, so I'm guessing I would still need the stock one? Can I get an aftermarket one that has AN8 fittings to replace the OEM one? Or is the OEM one just something you have to live with?
    • I say this and there’s a Nistune r34 GTT MT ECU for sale on eBay.de but I need to figure out compatibility between the AT harness and MT ECU - TCS considered. I figure this HKS SLD is a quick bandaid anyhow.
