R33 Gts4 Na
first of all i apologise if this question has been asked before but i did do a search first and couldn't find anything.
anyway, i need as much info on R33 GTS4 NA. every spec available, etc, etc.
i did try google and yahoo but just can't find anything about the GTS4 in particular.
any info would be awsome.
thanks alot.
My one weighs 1440kg and puts out approx. 140kw @ flywheel standard. And I *think* 230Nm of torque? What else you wanna know?
nice
cheers mate
140? would that be around 160kw at the crank?
bit heavier than what i thought but bit more power than i thought lol.
are they 4WS and 4WD or just 4WD?
also can you switch between RWD and 4WD?
i wouldn't think so.......?
Edited by duff man
i know there is a way to turn 4WD to RWD in the 32's but i think nissan fixed this in the 33's. But you can buy a HKS torque split converter to change it to RWD.
hey
i own one
very good handling i must say, power doesnt really kick in until 3000rpm
they come with 4stud hubs, smaller brakes then the turbo models
they hav a gtr drivetrain
other then that they are an ok car
i have plans to do either a engine conversion or turbo this motor
hey all,
Yeh i drive 96 series 2 GTS4 (annervsry addition with kool illuminated S K Y L I N E sybols at the back)
Yeh nice car is the Atessa 4wd system so its not 100% 4wd. Mainly rear. Once u loose traction then frontwheel kick in. On dash it shows SLIP 7 4wd.
im playing to do full engine conversion soon
peace
R33 Nissan Skyline GTS-4
Produced from 1993 (november)
GENERAL
Body type Coupe
Drive FULL 4WD
Transmission 5 speed floor shift with OD
Displacement, cc 2498
Frame E-ENR33
Price of new car, thousands yen (Tokyo area) 3018 (~$25100)
EXTERIOR
Exterior dimensions (LxWxH), mm 4640 x 1720 x 1355
Interior dimensions (LxWxH), mm 1820 x 1415 x 1090
Wheel base, mm 2720
Treads (F/R), mm 1460 / 1470
Ground clearance, mm 145
Curb vehicle weight, kg 1430
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 2
Min.turning radius, m 5.3
Fuel tank capacity, l 65
ENGINE
Engine model RB25DE
Max.power (Net), kw(PS)/rpm 190 ps (139.75 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm 23.5 kg*m (230.46 N*m) / 4800 rpm
Power density 7.53
Engine type Serial 6 cylinder DOHC24 valve
Engine information
Fuel system NISSAN EGI (ECCS) (electronic gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10
Bore, mm 86
Stroke, mm 71.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10.8
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 205/60R15 91h
Tires size rear 205/60R15 91h
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Independent suspension multiple link type
Suspension system, rear Independent suspension multiple link type
EXTERIOR EQUIPMENT
Sunroof / Moonroof (optional)
Front fog lamp (optional)
Rear wiper (optional)
Rear spoiler
ABS
LSD
Alloy wheel (optional)
INTERIOR EQUIPMENT
Air conditioner Full automatic
Central locking
Power window
Steering wheel tilt
Leather steering wheel
Rear ELR3 point seat belt
Side impact bar
Airbag (Driver) (optional)
Airbag (Passenger) (optional)
Car navigation system (optional)
COLOURS
White
Gang ray (PM)
Option
Black (super fine hard coat)
White (super fine hard coat)
Gang ray (PM) (super fine hard coat)
Spark silver two-tone (M) (super fine hard coat)
Super clear lead-lead (PM) (super fine hard coat)
Dark blue two-tone (P) (super fine hard coat)
Edited by Big Rizza
  • 4 weeks later...
I still rue the go-slow decision route I took when buying my turbo R33. The extra power definitely puts smiles on faces more frequently, but for forgiveable handling due to the Atessa 4wd, the GTS4 is a great value machine. The secret to getting good performance is to make them carry speed into/through bends with the engine rpm wound up!
Brake spec is lamentable, but cured with turbo-spec transplant. Not a race-car but provides good fun when the price difference is factored in.
  • 3 years later...
I own a gts4 and It's soo hard to get information about it. Thankfully to this forum I've got what I needed. I was wondering if 140kw is powerful. I think it's about 190hp but aren't the gts-t's around 240hps? That's why adventually I'd like to turbocharge my gts4 and try to get it up around 240's - 260's...
It's really good that the gts4 has the gtr's drivetrain as well because I didn't know that :O
It's really good that the gts4 has the gtr's drivetrain as well because I didn't know that cool.gif
Firstly... Thread revival, u must have dug for a while..
Secondly... They are not powerful... sorry to say any commodore past the VS era will demolish u, ur almost the same weight and down on power by heaps...
140kw is at the flywheel, ie what the engine makes, it losses a fair chunk of that by the time it gets to yours wheels...
at the wheels... the actual power stock you put to the ground is about 95-105kw... thats it...
I own a 96 gts4 myself, yes they are not the fastest things on the streets but they still make enough power to make P-plater happy lol. Great car as a starting point and gets u used to the car and u start learn more things about the RB and the Skylines. I for one enjoy it and my mate has a vt or vx? not too sure tp be exact as theyh look similiar and it kept with him the whole way so yeah all in all i would say they are a great p plater car, sound awesome too :)
  • 2 years later...
Nissan did not put it there from factory, the mount and bracket holes are there but i dont really know hw to explain where they are its easier if you just look at a GTS-T with it fitted, GTS-T and GTR may be the same as the swaybars are the same part NO#? im pretty sure....
Edited by central coast person
