Rx8 Turbo Kitq
Rotormaster in Sydney has a supercharger kit for the RX8 it utilise the standard exhaust and everything but has a substantial powe rincrease.
I believe a pro Charger is used which is sourced from the states
I have had interest in hearing more about this for a long time, but there seems to be very little information on it around... So far I have only found this:
From http://www.rotormaster.com.au/subPage.asp?cid=64
"Ready to roll...The New Rotor Master RX8 "Supercharger" Kit Supercedes the Stage 1 Turbo Kit!
After much research & further development to transform the RX8 Renesis Rotary Engine's power output, the crew @ Rotor Master are estatic with the results of their recently completed Stage 2 RX8 Kit with Joe opting to sideline the Turbo for the Pro-Charger!
The first Aussie assult on an RX8, Rotor Master first introduced the Stage 1 Turbocharger kit some 12 months ago & despite the unquestionable power gain, Joe & the crew still sought to increase performance levels.
So why the switch?
The GT 28 Turbo as used in the RM8 TurboChager Kit did not generate sufficient airflow & there was excessive exhaust pressure... enter the ProCharger with zero exhaust pressure and three times more air flow - a result on par with what you would expect from a TO4 Turbo!
Sheer determination coupled with persistant hard work has now produced a better overall product resulting in a kit now capable of producing a 303 rear-wheel horsepowered RX8!
(226 rear-wheel kilowatts on just 6 psi of boost with the car still revving to ten grand)... a relishing delight!
In terms of ECU, the kit is operational using a piggyback interface unit that manipulates the factory input sensors to obtain desired output (ignition & fuel delivery) when required - it all just simply plugs into place.
Enticed Yet?
So what's in the Kit?
The Rotor Master SuperCharger Kit includes a US-made ProCharger C-2, a DNA Motorsport PowerMod piggyback ECU, Front Mount Intercooler & Mounting components. The Rotor Master Kit is a ready-to-go kit that bolts into place with no major modifiaction work required - in fact installation (drive in-drive out) requires less than one days work!
Priced at AUS $11,900 in boxed form (ready to install) the SuperCharger kit is modest value with a 200+ kW rear wheel result with a standard exhaust system ensuring noise maintained at an appropriate level.
Plans for a Stage 2 SuperCharger Kit inclusive of an aftermarket fuel pump, larger injectors, aftermarket ignition systems plus smaller pulleys for around 10-12 psi of boost are already in motion. The Stage 2 kit hypothesised at producing over 400 rear-wheel horsepower, or around 300 rear-wheel kilowatts!"
Does anyone have any extra info?
    • You will need custom pistons made, the combustion chamber is to modified for any off the shelf piston to give a good compression ratio
    • Which is a thing done by no-one ever. Not even remotely a good idea. I would run an engine with 10:1 these days. Good management and fuel compared to the early 90s when these boat motors were designed & built.
    • I think you misunderstand. This was Greg driving from Melb to Syd (or return) at a constant 100km/h on the highway. Very little throttle movement, very little accel/decel. You should be able to get 8.5 l/100km under those circumstances (which is effectively what he reports - 50L for 600km is 8.3 l/100km). I drive my car to & from work every day, in traffic, on a mixture of 50, 60, 90 km/h roads (and therefore at up to 110km/h!!) with traffic lights and freeway sections. 28 km each way, so about a 30-40 minute drive depending on day, direction and traffic (which is enough for the majority of the drive to be "fully warmed up". I typically get flat 10 l/100km every single week. OK, maybe 10-10.5, every single tank of fuel. RB25DET Neo. It is easy to get acceptable economy. I won't say "good" economy, because modern cars are doing 5-6 l/100km in the same conditions.
    • Superpro are fine. There are some applications (R32 FUCAs for example) where they are no damn good, but typically for any normal suspension bush, they are fine. Some people will complain of them making noise. Some people will complain of them collapsing. But many of those can probably be traced back to not properly lubing at install or other installation problems, or possibly other problems elsewhere in the suspension that put additional load into particular bush. And for the legit complaints? Meh. Deal with it. I had to replace the poly bushes in my R32 FUCAs every year. The real issue is that I am sold on the idea of adjustability of at least upper arms. So I only have spots for poly bushes in lower arms these days, as everything else is either hardened rubber or spherical steel.
    • Suspension really is complicated.... All these considerations are making me over think it all. Again. I reckon I'll wait for SK's response on his coilovers, and go from there. Though if I go MCA, I'll have to decide on whether the extra $600 (voston comforts $1890, mca pro comfort is $2490) is worth it. Just something soft and comfy, yet firm enough when required at the track or a casual old pac drive for a pie... Otherwise, anyone have experience with SuperPro bushings? Needing to replace the bushings on the suspension department... Will probably keep the oem uppercontrol arms etc, and just replace the bushings.
