Auto Door Lock
Resin
anybody know where the auto door lock (at 20kms p/hour) is? Is it another box under that dash near the 105km chime?
I want to take mine out as it is playing up and trying to lock the doors when ur over 20km all the time ......sometimes when ur driving along it just keeps trying top lock em ...when they are already locked !.........anyway it must die !
thanks
yea mine does it sometimes but is getting worse and worse ....and once its starts it doesnt stop. tried doing what u do but it doesnt help .........i will have a look tommorrow
i have central locking ..................and hooked up to an immobilser ......its called old nissan electronics .......i have experienced it heaps with the nissan i have had ...my windows are also f**king up ....
yea mine is wired to the passnger doors aswell ..........
what is annnoying about mine is the fact that when im travelling above 20kms per hour the door locking mechanism constanly locks it self every 3 seconds
oh... that's wierd... its only supposed to fire once. Even if the lock is jammed it should only try once.
yea thats wats it used to do but over the last few months it has started going retarted.....it doesnt always do it ...
i think there is a faulty connection somewhere where it thinks the doors arent locked when they are.. or something like that
ok well lots of fiddling and trial and error and still have the problem but i think i know what is causing it.
Firstly the other two boxes under the steering wheel (to the right of the chime box seem to do nothing ....well i couldnt figure out what they did)
I realised it might be a earthing wire ....maybe worn and shorting? against the car or soemhting like that (i have had it before witht the stereo)
So i moved on to the drivers door. Through trial and error of unplugging connections and driving. I have found it to be somehting to do with the main power window box in particular the connections that drives the rear windows up and down ( i have also had issue with these ......they wind down fine with the drivers door but wont go up - i have to wind em up using the button on the door and if that doesnt work i have to press the buttons on both the drivers door and the passanger door!)
When i removed that coonection the constant locking stopped.
Also today the motor for the drivers door burnt out (probably to do with the problem i am having)
Any way thats how far i got ...and will keep looking during the week
My car does this too. I call it the Schitzo-fighting-feature. Basically something says you're "going over 10kmh .. quick lock the door." Sometime after something else says "the driver door just got unlocked, the rest of the car should be too" so it unlocks the car,.. at which point it says to itself "I'm going over 10kmh, quick .. lock the doors".. and it goes over and over.
You have 2 options -
1- buy a new central locking/power window controller console box thing
2- lock the drivers door
I went with options 2. Since you've got trouble with your windows go option 1... also get some silicone grease and give your window rubbers a quick spray (then wipe excess off the window). It'll feel like new :P
  • 6 years later...
After taking the Ceff for a quick spin around the block, i noticed that the doors auto lock at 20kmh, figured that it wouldn't be to safe to have this happening on the track.
So once again the dash came out and the drivers door card came off. I quickly worked out that the power window control thing in the door also controls the central locking.
20121119_006.jpg?w=1024
20121119_007.jpg?w=1024
both plugs are needed for both the power windows and central locking to work. After a quick inspection of the black plug, which had some wires running off to one of the door locks,
i noticed that there was one wire coloured in the same manner as a wire coming out of the back of the speedo behind the dash cluster. A quick multimeter test revealed that the yellow wire with a green stripe runs out of the back of the dash, to the ecm for speed cut as well as to the central door lock controller for the 20kmh auto lock feature. My sat between the purple, and blue with white wire on my loom. Yours may be different.
20121119_008.jpg?w=1024
now there are 2 option to potential fix this issue, one is to cut the offending wire, the other is to de-pin it from the plug.
first the 2 push lock needed to be bent out and the locking flap comes straight up. then you need to inset a thin flathead screwdriver into the large opening on the face of the plug and pry out the plastic clip that hold the pin inside the plug, i got frustrated and just snapped the f**ker out.
20121119_010.jpg?w=1024
Don't know if this will stop the door from locking automatically at 20 kmh as i can not get the car out of the driveway.
after the weekend i will know if this is it, and update this post.
    • G.G.C. (Gibier German Cook) restaurant in Motomachi in Kobe: A tiny 2 floor restaurant that was founded in 1976. The original couple who owned/ran it retired and sold the business to a corporation who pretty much tried to keep it the same as it was.  Lots of lesser known (to me anyway) German beers available.  Venison with vegetables. The meat came from deer from Hokkaido. The chef told us that there's a whole industry around the use of all parts of the deer from the antlers to the hooves. Sure enough, directly accross the street from this restaurant is a shop that sells all manner of utensils, clothes and objet d'art all made from deer skin, bones and horns.... also owned by the same corporation. The venison was super tender 😋 Various decorations, a lot of which were quite old, no doubt from the original owners. A nice pilsner too which I'd never seen before.  It's well worth a visit but check the opening hours, they're closed on Wednesdays, only open 11:30am - 3pm on Mondays and Tuedays, 11:30am-3pm for lunch and 5pm-11:30pm on Thursdays, Fridays and Saturdays, and 11:30am-3pm and 5pm-9pm on Sundays. Last order is 30mins before close.
    • Yep around 2m long or thereabouts.  I made another post in the photo diaries 17 years later lol. I swear it has not been that long!
    • Full results via link below https://docs.google.com/spreadsheets/d/1inu1mRRO0WjV2-3vGYsjnmYggVOzmApWOby68GwPGcI/edit?usp=sharing
    • Have I not posted since 2022 ? wow... Yes, it's pretty much finished mechanically. I'll probably sell it soon as the old man is 80 in November, so 99% he won't ever drive it again. I don't really need 3 GT-R's and I haven't driven any of them since September last year - correction, drove my 33 earlier this year on Australia day. All of them have been like this since then.
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
