19 Aug 2006, 12:04 PM
From RB25 to VQ35 ![]() ![]() Posts: 3,185 Joined: 16th June, 2002 From: Cairnlea Car(s): R33 (Sold), RAV4, V35 Real Name: Rianto Trader Rating : 84 |
UPDATED 20/9/2006
ALL 2 BATCHES SUBMITTED (26 PEOPLE, ALMOST 40 PAIRS OF ROTORS) SUCCESSFULLY. GROUP BUY HAS ENDED. GROUP BUY RE-OPENED, THE 3RD BATCH IS IN THIS NEW THREAD Hi All, I had contacted a rep from the RDA Brakes (Rotors & Drums Australia) and they're willing to give a good deal/discount depending on the qty that we ordered. Slotted Rotors ![]() Grooved Dimpled (Dimpled & Slots) ![]() More info can be found here: RDA Brakes Products Also, I have attached a zip file of RDA disc rotor part number for Nissan cars (Download and open Zip file, then open the XLS file, and just click read-only at the password prompt). [attachment=52329:attachment] The list of group buy people is as in this spreadsheet (zipped): <spreadsheet removed to protect pricing structure, not available to general public, only to serious buyers pm me only> People listed above please open the spreadsheet attachment and see if your car, slot/dimple, and front/rear options are correct. PM me with any errors or amendments, do not update the excel spreadsheet. I will confirm the part numbers with RDA so to ensure you will get the correct parts. Regards, Rianto -------------------- |
19 Aug 2006, 02:10 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,086 Joined: 27th May, 2003 Car(s): R32 GTR Trader Rating : 18 |
iam gueesing r32 gtst is included in the group buy?? if so iam in
19 Aug 2006, 04:39 PM
Ex-Skyliner ![]() ![]() ![]() ![]() ![]() Posts: 1,034 Joined: 11th September, 2005 From: Moon. With the soy sauce Car(s): '72 HQ Premier Trader Rating : 0 |
depends how much i'm quoted on a pair from another source... i may be in as my front rotors need machining so i might as well upgrade...
how long till close? id need about a fortnight... :S -------------------- ![]() No longer an owner of a R33 GTST... :( |
19 Aug 2006, 09:55 PM
Rank: RB20DET ![]() ![]() ![]() Posts: 38 Joined: 3rd June, 2006 From: sydney Car(s): R32 Skyline GTR Real Name: Binh Trader Rating : 1 |
I'm in need of a pair of front and rear rotors for a R32 GTR
Crossed drilled and slotted is preferable. Thanks |
19 Aug 2006, 11:07 PM
lunaticR32 - i've put you in, r32 gtst should be no probs, I think you can use the same rotors as r33 gtst ones, i've got an excel sheet of all nissan parts they have i'll check later.
freddykruger - at the moment we're still gauging interest so I can go back to RDA n say "x ppl interested and about x pairs of rotors will b ordered, what's ur best deal?" you can jump in later once the group buy starts rolling. prelude_1976 - i've put you in. don't think they make cross drilled. even DBA discourage use of cross drill in hi performance applications as they tend to crack. for best strength maybe you'd b better off with dimpled ones (see pics on 1st thread). but i'll ask the guy at rda if they can cater your need. -------------------- |
20 Aug 2006, 02:00 PM
Dimpled and slotted is fine.
Ive got cross drilled at the moment and its got deep grooves from the pads, so totally unserviceable, hence the need for new rotors. Put me in for front and rear, R32 GTR Thanks |
20 Aug 2006, 02:19 PM
#7
![]() 100% Dizko Shit ![]() Posts: 1,302 Joined: 6th September, 2005 From: Brisf**kenvegas Car(s): GTR R33 LM Vspec+Camry Trader Rating : 5 |
im definately interested.
whats the difference between those two type of rotors for a R33 GTR?? they have different prices -------------------- GTR is God himself scaled down into drivable form
20 Aug 2006, 02:29 PM
#8
![]() S2-R33 ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,615 Joined: 4th August, 2004 Car(s): Silver 33 Trader Rating : 24 |
^^ im guessin ones just your normal slotted ones..
The other ones have dimples in them (the little holes) plus the slots.. So greater effect of removing dirt and cooling etc etc.. -------------------- Successful traders:
C & B, Mr_G, z3n2k, r33skyliner, RBFIRE, mr_crust, bigsully84, BT-Revolution, PAV34, BATMBML, raz0r$harP, r33skyline, slide-performance, Bass Junky, moonus, erwin_skyline |
20 Aug 2006, 03:43 PM
#9
frankxinyu, I'll put your name in the list.
basically the dimples one are almost like cross drilled. but unlike cross drilled where the strength and integrity of the disc could be compromised by removing the material from the drilling process, in dimpled that effect is not as bad. you've still got the slot to disperse the build ups between pads and rotor surface, plus the dimples also helps it even more, and cosmetically it will look as if a cross drilled rotors. -------------------- |
20 Aug 2006, 04:05 PM
#10
![]() Ginger Breadman ![]() ![]() ![]() ![]() ![]() Posts: 312 Joined: 14th September, 2004 From: Gladstone Car(s): R33 Gts-t Real Name: Bill Trader Rating : 2 |
Hey, im interested in slottted front and rear for r33 gtst.
Cheers. -------------------- R33 gts-t, 13.624
Mods: 3 Inch Mandrel bent stainless Exhaust, Pod Filter, Boost controller, FMIC, CAI, Splitfire coils, Front and rear strut brace, D2 coilovers, short shifter, Consult Diagnostics..... Click to see more. Earn REAL money online....CLICK ME |
20 Aug 2006, 04:18 PM
#11
Hi,
R32 GTR rotors are : 296mm x 32mm = Front 297mm x 18mm = Rear If u can get these dimensions i'm in for front and rear |
20 Aug 2006, 04:46 PM
#12
![]() AX53B70 タービンの ![]() ![]() ![]() ![]() ![]() Posts: 1,489 Joined: 4th June, 2004 Car(s): RB30DET R33 Trader Rating : 15 |
Hi rs73
Good work with the gb thread -------------------- ![]() |
20 Aug 2006, 09:22 PM
#13
Hi rs73 Good work with the gb thread i'll ask them a rough estimate of delivery costs... -------------------- |
20 Aug 2006, 09:42 PM
#14
![]() Rb25det Neo ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,550 Joined: 16th November, 2004 From: Brisbane Car(s): Stagea S2 Type-R Real Name: Darrin Trader Rating : 5 |
R34 GTT front slotted 310mm??
20 Aug 2006, 10:04 PM
#15
R34 GTT front slotted 310mm?? I'm asking that to RDA at the moment, waiting for their reply. They should have the same size with DBA as their part no can be cross-checked with DBA as well. Have a look at the first post, I have added an XLS spreadsheet attachment for all Nissan cars. (You do not need to enter password to open the file in read-only mode). I;ve added myself in the list as I want the rear slot rotors -------------------- |
20 Aug 2006, 10:29 PM
