IPB
> Tutorials / DIY / FAQ Rules
2 Pages V   1 2 >
> How to stop your brakes squealing 101
JimX
post 13 Jul 2004, 04:52 PM
Post #1
random engine
Group Icon
Car(s): 95 GTR33, 02 GSXR1000
Real Name: Jim
Trader Rating : 11
When I got my RB74 pads, they were rather quiet. After several months though, the right front brakes started to get a little noisy. When it got to the stage where it would squeal on every slowdown, I decided to see if I could fix it (well, I put it off for a few weeks because I'm a lazy bastard). Here's the brief rundown on how I did it.
1. Buy some red gooey anti-squeal stuff from my local spares shop.
2. Buy 1-2 sheets of 80 grit emery paper from the same shop (around $1.25 a sheet)
3. Jack car up, remove offending wheel.
4. Remove clips and springs from pads.
5. Remove pads from caliper.
6. Sand back the pads on the emery paper until the glazed surface is roughened up. There may be some scoring marks left on the pads, it's not essential to get rid of every little groove.
6a. If your discs are badly scored, get them machined. Maybe you should figure out whether or not they need machining before you sand the pads back.
7. If the discs are fine and you can be bothered, give the discs a quick once-over with the emery cloth. It's pretty difficult to make even a light indent in the discs though, so don't worry too much.
8. Put red gooey stuff all between each layer of pad and backing plate, as well as on the back of the plate that sits on the caliper piston.
9. Put pads back into the caliper after the red gooey stuff goes tacky.
10. Bend the anti-squeal spring in the opposite direction a bit, to give it more tension for when it's in place.
11. Put spring and clips back in, put wheel back on, etc etc.
12. Test everything.
13. If you crash your car for any reason, don't blame me (disclaimer).
It's weird how only my right front brake started squealing. The left front one has remained quiet all this time so I didn't bother doing that side. I only fix what's broken smile.gif
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Duncan
post 13 Jul 2004, 09:13 PM
Post #2
that's racing!
Group Icon
Group Icon
Group Icon
Group Icon
Car(s): bnr32,z33,wgnc34,ungd21
Trader Rating : 19
Great post jimx, do you mind if I move it to the FAQ section?
Profile CardPM
+Quote Post
JimX
post 13 Jul 2004, 10:24 PM
Post #3
random engine
Group Icon
Real Name: Jim
Trader Rating : 11
Profile CardPM
+Quote Post
nigelswazi
post 21 Jul 2005, 09:20 AM
Post #4
Trader Rating : 6
Ever had the calipers overhauled? U might have some pistons not moving in one
Profile CardPM
+Quote Post
ferni
post 21 Jul 2005, 01:15 PM
Post #5
1.48@PI. Daily Driver.
Group Icon
Group Icon
Group Icon
Car(s): R33 GTR + Golf GTI
Real Name: Andrew
Trader Rating : 17
whats the anti-squeal spring your talking about?
Calder - Isn't that where those drag posers go? ;)
Phillip Island - 1.48.9 not bad for me.
Sandown - 1.22.44 first time there.
Winton - 1.37.51 need to go faster.
1/4 Mile - something@120mph
Profile CardPM
+Quote Post
someonestolecc
post 21 Jul 2005, 01:22 PM
Post #6
name = cc
Group Icon
Trader Rating : 4
Whats the red goo do?
Team I need $
Profile CardPM
+Quote Post
Munna
post 21 Jul 2005, 01:29 PM
Post #7
Trader Rating : 0
QUOTE(someonestolecc)
Glues the pad to the caliper pistons to stop it rubbing against the disk.
Nissan Skyline Specifications and tuning guides
Nissan Skyline
Full 3" Exhaust, SAFC2, Hybrid intercooler, 10.5psi boost
195.7 rwkw
Profile CardPM
+Quote Post
madmoomoo
post 22 Jul 2005, 11:17 PM
Post #8
Car(s): '93 R33 gtst
Trader Rating : 0
I had bendix ultimates and they squeeled like a beatch and drove me nuts. I went and bought some of that anti squeel spray but it didn't help me at all ( i still had anti squeel shimmy things in there though). When I changed brake pads I got LUCAS ones put in, and they have not made a single noise ever!
I'm so impressed with these pads, they stop beautifully, don't leave my rims as filthy as the bendix ones, and they don't squeek!
So there's my advice, use the Lucas pads! (I've heard the RB ones are a bit squeeky too!)
Profile CardPM
+Quote Post
NZM.031
post 23 Jul 2005, 06:24 AM
Post #9
registered stooge
Trader Rating : 0
my RB74s squeal as i back it out of the shed... after that though, they dont make a peep.
Monkeykplunk has ultimates and they never shut up.
Linton
Profile CardPM
+Quote Post
r33GTS-t-200kw
post 23 Jul 2005, 10:24 AM
Post #10
Trader Rating : 0
u can make ur ultimates quiet... just re-scuff the pad surface, and chamfer the front and rear edges so there is a 45 degree angle of chamfer... if you get what i mean.. glue them in and they are good to go
always
Profile CardPM
+Quote Post
DRFT33
post 10 Sep 2005, 06:47 PM
Post #11
Real Name: Richie
Trader Rating : 0
its mainly just the dust that makes the pads squeal after awhile. i have ferrodos that are hell dusty. i just got some anti-squeal from my work, cleaned up the discs and pads, put it on the back of the pad, includin the spring and it has never sqeualed again.
Profile CardPM
+Quote Post
Cubes
post 11 Sep 2005, 11:35 AM
Post #12
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
Garage: HCR32 - 400rwhp
I've had Ultimates, from readings I was expecting them to squeel so I bought my self a tube of PBR anti-squeal adhesive, slapped it every where over the back of the disk and antisqueel shims.
The car was only driven on the street and never saw anyhard braking.
I use and recommend
Profile CardPM
+Quote Post
Big B R33
post 29 Dec 2006, 02:26 PM
Post #13
Rank: RB20E
Car(s): R33 Skyline GTS25t
Real Name: Brian
Trader Rating : 0
What is the red goo glue called?
Profile CardPM
+Quote Post
MANWHORE
post 29 Dec 2006, 03:35 PM
Post #14
97r33gtst-typeM
Trader Rating : 23
It's called anti squeel shit. go to any auto store lilke repco, supercheapauto, autoone or autobarn
For Sale:
vg turbo (suit highflow) $350
rb25 turbo (suit highflow) $150
torque wrench $20
Stock turbo related bits for installing turbos - actuators, copper washers, oil drains, exhaust housing studs, bolts, nuts.
Profile CardPM
+Quote Post
Cubes
post 29 Dec 2006, 03:54 PM
Post #15
400rwhp - 3000cc
Group Icon
Group Icon
Group Icon
Car(s): R32 GTS30t
Trader Rating : 10
PBR do an antisqueel glue.
I've always used it and never had issues, ultimates only squealed just before you came to a stop, so bearable.
I use and recommend
Profile CardPM
+Quote Post
justin911
post 29 Dec 2006, 03:58 PM
Post #16
^^^ need roof wheels :(
Group Icon
Car(s): R33 GTR
Trader Rating : 26
my ultimates used to squeel as if they were getting molested or something..
i tried the paste stuff which didnt do anything at all..
the spray worked realy well tho smile.gif fixed it up 100%
alltho i have a feeling the spray doesnt work for all that long ??
Profile CardPM
+Quote Post
BAMR33
post 29 Dec 2006, 06:47 PM
Post #17
Car(s): 95 type-m Skyline
Real Name: Brett
Trader Rating : 11
Just cross hatch the rotor with emery paper, around 80 grit as mentioned. The sqealing is caused by dust build-up in the grooves of the rotor. Don't be scared of giving them a good rub too.
My vote, the 'red gooey stuff' is not required.
Profile Card
