9 Jun 2005, 11:39 PM
![]() JUN RB27DET - HKS T04Z ![]() ![]() ![]() ![]() Posts: 433 Joined: 29th May, 2005 From: Perth WA Car(s): GTR wagon, VS Berlina Trader Rating : 0 |
hey guys well after my recent axle snapping of the stock stagea diff, well i presumed the diff had same axles as gtr so i got a gtr axle sent to me and when i put them side by side the gtr is like HUGE in comparision and the uni joints are twice the size, ill post pics when i get some spare time
so we have decided the piss weak stagea diff had to go, so once i removed it i open the back plate up to reveal a open wheeler POS :confused: so that was even more reason to ditch the stagea diff and pencil thick axles :uh-huh: well i just picked up the gtr diff/axles/brakes/arms/whole rear end pretty much for a bargain from a friend :jump: on the weekend im gonna see how easy its gonna fit ill keep you guys posted on how it goes and only issue is whether the original 4.3 gears will fit in the gtr diff or not and if not i got a spare set of 4.11 front gears so ill have to change them otherwise :uh-huh: cheers Brad -------------------- |
10 Jun 2005, 12:12 AM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 427 Joined: 8th May, 2005 Trader Rating : 17 |
just make sure the ratios are the same...
they probably are, but it always pays to check. If the ratios are different, you may find yourself doing a front diff aswell -------------------- I have a broken watch, and even thats right twice a day.
10 Jun 2005, 08:34 AM
ratios are definately different, as gtr has 4.11s and stagea is 4.3s so im gonna try fitting the 4.3 gears in the gtr diff, or otherwise i have to swap the front diff gears to the gtr original 4.11s which luckily i got a spare set sitting in the garage ready if need be :uh-huh:
10 Jun 2005, 11:45 AM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 209 Joined: 4th June, 2003 Trader Rating : 0 |
At least now you wont heopfully have any more breakage back there
10 Jun 2005, 12:37 PM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,870 Joined: 21st April, 2002 Trader Rating : 40 |
Good info Brad,
So the LSD on the RS4's must have been an option.. hmmm... You'll notice an improvement in acceleration if you go with the 4.11 gears, but at the sacrifice of a bit of fuel ecconomy though J Totally off topic.. I found out why my coffee cup leaves a bit of hot water when I half fill it.. A hair line crack in the side of it. It's had me puzzled for weeks until today when the crack is now noticable.. lol |
10 Jun 2005, 01:00 PM
I think you got it backwards JAY95R33
wont you get better acceleration with the 4.3's??? -------------------- I have a broken watch, and even thats right twice a day.
10 Jun 2005, 03:12 PM
#7
D'oh - I always get it around the wrong way lol
12 Jun 2005, 04:58 PM
#8
well i been comparing the sizes of the diff parts compared to the gtr parts and here are the measurements
Splines into hub stagea 29.82mm gtr 32.65mm axle thickness stagea 28.07mm gtr 30.07mm swaybars stagea 19.25mm gtr 25.60mm rear brake rotors stagea 265.05mm gtr 297.02mm axle to diff uni joint size stagea 90.63mm gtr 98.94mm so theres some interesting figures showing nissan sure did save on the $$$ when selecting parts for the stageas :chairshot also on a side note the transfer case in the stagea auto compared to a gtr manual one has only half the strength components and doesnt compare to the gtr as they only have 4 lugs pushing the clutch packs together and the gtr has 8 which is a huge difference, ill take some shots to show you's anyway. cheers Brad -------------------- |
12 Jun 2005, 06:17 PM
#9
Rank: RB20DE ![]() ![]() Posts: 17 Joined: 11th June, 2005 Trader Rating : 0 |
Cheers for the breakdown Brad. How long have you been playing with the stag for?
12 Jun 2005, 08:23 PM
#10
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 273 Joined: 5th November, 2002 Trader Rating : 1 |
So how do those mesurments compare to a R33 GTS-t
-------------------- Stagea RS4
Dato 1600 Rally Car Gemini Turbo Diesel 66 Mustang |
13 Jun 2005, 08:31 AM
#11
QUOTE(ACAVant) Cheers for the breakdown Brad. How long have you been playing with the stag for? no worries guys i bought the stagea at the end of november last year so about 6 months i been playing ta Brad -------------------- |
13 Jun 2005, 09:38 AM
#12
![]() NEO RB25DET * 2 ![]() ![]() ![]() ![]() ![]() Posts: 591 Joined: 5th April, 2003 Car(s): R34GTX Turbo, Stagea RS4S Trader Rating : 0 |
QUOTE(Jay95R33) Good info Brad,
So the LSD on the RS4's must have been an option.. hmmm... Yep, they were optional on the auto's, but came as standard on the manuals... So check to see if your (auto) car has one before you buy it! :-) Ian -------------------- |
13 Jun 2005, 09:47 AM
#13
![]() Doctor of Internal Combustion ![]() ![]() ![]() ![]() Posts: 138 Joined: 5th June, 2005 From: Toowoomba Car(s): 98 S2 Stagea Real Name: Jeff Trader Rating : 0 |
QUOTE(ian) Yep, they were optional on the auto's, but came as standard on the manuals... So check to see if your (auto) car has one before you buy it! :-) how can you tell? |
13 Jun 2005, 05:53 PM
#14
![]() not guilty ! ![]() ![]() ![]() ![]() ![]() Posts: 870 Joined: 19th October, 2003 From: Earth Car(s): 260RS Real Name: 0412 002 798 Steve Trader Rating : 5 |
QUOTE(StageZilla) well i been comparing the sizes of the diff parts compared to the gtr parts and here are the measurements Splines into hub stagea 29.82mm gtr 32.65mm axle thickness stagea 28.07mm gtr 30.07mm swaybars stagea 19.25mm gtr 25.60mm rear brake rotors stagea 265.05mm gtr 297.02mm axle to diff uni joint size stagea 90.63mm gtr 98.94mm so theres some interesting figures showing nissan sure did save on the $$$ when selecting parts for the stageas :chairshot also on a side note the transfer case in the stagea auto compared to a gtr manual one has only half the strength components and doesnt compare to the gtr as they only have 4 lugs pushing the clutch packs together and the gtr has 8 which is a huge difference, ill take some shots to show you's anyway. cheers Brad so what your saying is that the 2.5 stagea doesn`t really have a gtr "driveline " to start with....thanks mythbuster ps: autech stagea has different wheel offset +30 front +20 rear due to different diff/ housing width than 2.5 . +30 need adapters to fit rear it may be something you come up against:cheers: -------------------- GREY IMPORTS AUSTRALIA P/L
RAWS ID #10313 R34, EVO 6 ,EVO 7, EVO 8 ,JZX100,JZX101,P35W/P25W DELICA COMPLIANCE AVAILABLE |
14 Jun 2005, 09:57 AM
#15
QUOTE(Techo) how can you tell? Pull over during a test drive and tell them you are going to check if there is an LSD. Put it in D, hold the brake down, push accelerator until the car creeps, at the same time floor it and release the brakes, then feather the brakes. Hopefully you get some type of wheel spin, look at the rear if it left marks, 2 marks = LSD :Pimp2: |
14 Jun 2005, 10:08 AM
#16
QUOTE(AlexCim) Pull over during a test drive and tell them you are going to check if there is an LSD.
Put it in D, hold the brake down, push accelerator until the car creeps, at the same time floor it and release the brakes, then feather the brakes. Hopefully you get some type of wheel spin, look at the rear if it left marks, 2 marks = LSD :Pimp2: Alternatively, and I've done this in my youth more than once :-), from a standing start put your foot all the way to the floor, and once you moving OK (say about 4 seconds later) do a sharp 180 degree corner (foot still flat to the floor). If you hear a cracking noise and loose power half way around, you do not have a LSD.. :-) Ian -------------------- |
