9 Jul 2002, 10:31 AM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 599 Joined: 23rd April, 2002 Trader Rating : 1 |
What sparkplugs do you guys recommend I put in my car? I'm running slightly higher boost (10psi) so I'm thinking of 0.8mm gapped plugs. Do I have to buy 1.1mm and gap them myself or are there 0.8mm plugs for an R33 gtst available?
9 Jul 2002, 01:44 PM
![]() 400rwhp - 3000cc ![]() ![]() ![]() Posts: 15,137 Joined: 20th June, 2002 Car(s): R32 GTS30t Trader Rating : 10 Garage: HCR32 - 400rwhp |
I'm pretty sure that NGK sell both .8mm gapped and 1.1mm gapped plugs. I think say for example BCPRE6E or what ever it is is gapped to .8mm and if the same BCPRE6E-11 or somthing is gapped at 1.1mm
I'm pretty sure but don't quote me Check NGK's WWW site there is a legend to tell you exactly what every letter and number means in the code. Anyway I'm running or I will be soon the NGK's V Groove Coppers gapped to .8mm and they are 1 range cooler than normal plugs as I am running 14psi, it supposivly prevents detonation as there is less heat in turn you can run more advance with the higher boost levels. Until I get the mods finished then I will slap a set of platiniums in. Note with the heat range cooler apparently they can cause a little bit of a grumbly idle. I will find out i guess. -------------------- |
9 Jul 2002, 05:59 PM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,818 Joined: 12th June, 2002 Trader Rating : 0 |
ive heard platinums are obviously better but not worth the extra money....
anyway go for a 0.8mm gap if youre running 10psi and a plug like NGK should be fine |
9 Jul 2002, 06:41 PM
The difference is i guess that plats last up to 100,000kays for approx $100 for set where as for coppers they only last 10,000-20,000 kays for around $30 bucks a set.
Plus fiddling with those dodgy coils, I'd rather change every 100,000kays. -------------------- |
9 Jul 2002, 07:06 PM
what plugs come stantdard?
ones which you have to change 10-20000ks? cos my car desperately needs some new plugs |
9 Jul 2002, 07:10 PM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,441 Joined: 22nd April, 2002 Trader Rating : 0 |
Pretty sure they all came with platinum plugs standard
-------------------- Ummm........I got nothing :stupid:
Pointless thought of the week If i right nothing in this space, will anyone still read it ? |
9 Jul 2002, 07:33 PM
#7
Rank: RB30ET ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,877 Joined: 15th April, 2002 Trader Rating : 0 |
wow. so when i changed my plugs a few weeks back, the platinums i threw out were in there for 7 years!?
9 Jul 2002, 08:27 PM
#8
QUOTE Originally posted by ONARUN
wow. so when i changed my plugs a few weeks back, the platinums i threw out were in there for 7 years!? You had your 'Line for 7 years? wow! Anyway I've asked around and the NGK Iridium plugs are the best. They last 100,000kms and come in gaps of .8, .9 and 1.1mm. The model number for the RB25DET is BKR5EIX so I'll be picking up a set of these tomorrow for $18.50 a plug. I hope they go well... |
9 Jul 2002, 08:29 PM
#9
No his cars 7 years old...
9 Jul 2002, 09:06 PM
#10
I remember hearing some bad things about the iridiums..
Do a search on SDU. -------------------- |
10 Jul 2002, 11:39 AM
#11
![]() fangartists.com ![]() Posts: 464 Joined: 1st June, 2002 From: Melbourne Car(s): Evolution IX Real Name: Matt Trader Rating : 0 |
You're kidding yourself if you think platinums will last 100,000kms! I've gone through 2 sets since I've had my car, and i've only had it 2 years. If your car is like every other skyline out there and runs rich, you're not going to get any more than 20-30,000kms out of em before they start to lose their efficiency.
For $2.50-$3 each for copper ngk's, I know what I'll be using. Not sure how that works out to be $30 bucks! My cars running 1.2-1.4 bar of boost, and I've had no problems with spark. matt QUOTE Originally posted by -Joel-
The difference is i guess that plats last up to 100,000kays for approx $100 for set where as for coppers they only last 10,000-20,000 kays for around $30 bucks a set. Plus fiddling with those dodgy coils, I'd rather change every 100,000kays. |
10 Jul 2002, 01:34 PM
#12
![]() Ohhh Nurse Arkady.... ![]() ![]() ![]() ![]() ![]() Posts: 1,058 Joined: 31st May, 2002 From: Melbourne Trader Rating : 6 |
Should search around on SDU first as this question has been answered many times before in the past.
Basically as matlowth said, they do get fouled easily b/c of the fuel mixture, so coppers are the way to go... The more expensive plugs dont give more power, but do last longer and use better conductors, so a copper plug needs a smaller gap so the spark can jump. Higher boost also means you need a smaller gap, as does a colder heat rating spark. If you dont have a heavily modded car, then the plug you want is NGK BCPR6ES. They are gapped to .8 mm and will do the job well. Dont bother getting a colder plug BCPR7ES as I did. Because my car is stock (besides exhaust and boost), the colder heat rating dont work as well... Zahos |
10 Jul 2002, 11:34 PM
#13
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 217 Joined: 31st May, 2002 Trader Rating : 0 |
I use NGK iridiums gapped to .8mm with 6 heatrange and they run really well. Cost about $18 each from autobahn. Haven't had any problems at all.
I run a front mount intercooler, exhaust and boost upped to 10PSI if that helps. |
11 Jul 2002, 01:16 AM
#14
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,461 Joined: 18th April, 2002 Trader Rating : 0 |
guys u are kidding ureselves if u think u will get anywhere near 100,000 km for a set of platinums on a modded car.. go coppers... u might have toi change ever 10,000km but at like 15-20 bux a set.. u get a BRAND NEW set of plugs each time..
-------------------- U WERE MINE....
Rip URMINE 8/7/03.... Never forget thy yellow dildus.. |
11 Jul 2002, 01:47 AM
#15
Well I went with the Iridiums that cost me $111 for the set. I decided on the iridiums simply cos I'm running a SAFC to fix the richness problem plus I'm running higher boost. I got the 0.9mm gapped plugs with a temp rating of 6. I'll probably end up taking them out every 20,000kms to clean them anyway so perhaps the coppers are the way to go...
11 Jul 2002, 05:02 PM
#16
![]() Mr. Snrub ![]() ![]() ![]() ![]() ![]() Posts: 543 Joined: 31st May, 2002 Car(s): BNR32 Real Name: Mr. Snrub Trader Rating : 3 |
i use ngk coppers... only 24 bux for a set of 6 and thats all you need! i read somewhere though that you gotta replace coppers every 10thou k's so. compared to the iridiums that i had (damn $80 too) its very good. one i use are NGK's BKR7E:- pre-gapped to 0.8 and one heat range colder.
-------------------- teh GTR can nevah lose!!1one!1 | VTEC just kicked in y0!
www.users.on.net/~ula |
11 Jul 2002, 07:03 PM
#17
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 115 Joined: 24th April, 2002 Trader Rating : 0 |
I'm running NGK iriway 7's and they are awesome. I paid $18 each. They are not like the normal iridiums IX they come gapped at 0.6mm and come in colder heat ranges 7,8,9. NGK state that you shouldn't regap iridiums. If anyone wants a set of NGK IRIWAY, IRITOP, IRIMAC spark plugs drop me an email and i will hook you guys up. BTW I am not |
