Sau Timeslip Registry
BU5TER
Post your times here with a link to your timeslip and we'll get a new registry happening
Please post what tyres
nitrous or not
race fuel or pump fuel
Nissans only
thanks Brett
GTR
1: Giant
ET:10.207
MPH:137.91
60':1.556
Tyres:RE55 SEMI SLICKS
Nitrous:not
Race Fuel:VP109
Nissan:R32 GTR
2: Dirtgarage 10.36, 60':1.493, MPH: 133.9, Mickey Thompson drag radials, C16
3: easyst
ET:10.56
MPH:132
60':1.67
Tyres: M/T ET streets
Nitrous:no
Fuel: BP ultimate
Nissan:R32 GTR
4: GOT BOOST R32 GTS-4, ET:10.982, 60':1.754, MPH:129.68, 235 45 17 firestone on front, 235 45 17 nankangs on rear, BP ultimate
5.T04GTR ET: 11.324. MPH: 122. 60':1.782 . TYRES: FEDERAL ss595 .nitrous: no .fuel: OPTIMAX . nissan r32gtr
6: pnblight GTR R33, ET 11.332, 60' 1.757, tyres federals, bp ulimate
MPH 125.17
7: wrxkilla 11.496, 60':1.718, MPH: 120.93, Crap bridgestone compliance spec, BP ultimate
8: Tommyk R33 GTR Vspec, ET: 11.914, 60': 1.809, MPH: 114.56, Tyres: Toyo Proxes T1-R, FUEL: Shell Optimax
9: BenM - 12.348sec @ 113.56mph, 60' 1.793sec, Nankang 255x40x17 street tyres, Shell Optimax, WSID
10: PSI GTSII
11.9 @ 117mph - 390rwHP
Totally Standard except:
PFC
GT2560r's
Trust/Greddy front and Dump pipes
Jasma 3" exhaust
11:RellikZephyr
R32 GTR
Power: approx 300hp
ET:12.767
MPH:105.883
60':1.810
Tyres: Bridgestone Potenza GIII on Std BNR32 Rims
Nitrous:No
Fuel: Shell V-Power
12: Yorik 12.78, 60':2.079, MPH: 110, Bridgestone RE's, BP ultimate
GTST
1: jas/slo32 9.769, 60':1.493, MPH: 141, Mickey Thompson Slicks, C16
2: BU5TER 10.557, 60':1.795, MPH: 130, Mickey Thompson drag radials, BP ultimate
3: TurbostyleR
ET: 11.1
MPH: 131
60': 1.60
Nitrous: no
Fuel: BP ultimate + octane booster
Nissan: S13 silvia
4: slapper - 11.576 @125.10 mph, 60' 1.800 sec, Hoosier 225 x 50 x 16" drag radials, Nitrous-NO, Shell Optimax Extreme, Willowbank
5: NA_R33 11.644, 60:1.702, MPH: 120.29, 26 by 8.5 American Racing Slicks, 50% Toluene 50% BP Ultimate
6: 2RISMO 11.662, 60':1.700, MPH: 118.34, 255/50/16" MT Drag Radials, Mobil Synergy 8000 and NITROUS
7: ADDS 11.778, 60':1.712, MPH: 117.34, Very old slicks, BP ultimate
8: OFENSV 12.175, 60:1.881, MPH: 118.14, 235/60/15 MT drag radials, optimax and ooctane booster
9: Abo bob Shell v-power racing
Mickey Thompsons
60' - 1.783
330' - 5.132
660' - 7.981
mph - 87.71
1000' - 10.372
ET - 12.419
mph - 110.53
10: TheLast
ET:12.467
MPH:103 (have run as high as 115 car lost power at 1000ft it was low on fuel)
60':1.898
Tyres: kumho SPT 225/50/16
Nitrous:no
Fuel: VP 103
Nissan:R32 GTS-T rb20 stock long block
11: Robo's 12.554, 60':2.036, MPH: 113.52, SUMITUNOS HRZ, Optimax
12: GTShortie 12.578, 60':1.908, MPH: 113.39, 255/50/16" MT Drag Radials, Shell V-Power Racing R33 GTST
13: Bass Junky 12.8696 @ 113.72, 60ft 2.1538, Circuit Tyres, Heathcote Park
14: bigcarl: 12.991, 60':2.146, MPH: 108.18, 225/50x15 semi comp 18psi, pump fuel
15: ECR033 12.993, 60':1.777, MPH: 104.4, BFG Comp T/A, BP ultimate
16: Bass Junky 13.071 @ 108.91, 60ft 2.235, Hankook Ventus Sport, Calder Park
17: yummy
r33 gts-t
et: 13.0@110mph
60': 2.007
tyres: old bridgestone potenza re540s 225/50/16 circuit semis, 28psi
fuel: bp ultimate
18: R31 POWER, R31 Silhouette, ET:13.8, 60':2.378, MPH:103, TYRES:255/40/17 Federal SS595, BP Ultimate
19: Nismo God
Stock r33 with turbo back exhaust
13.813 @100.92mph
60ft 2.20
pulp 98, on 275/30/19
20:WazR32GTSt, R32GTSt automatic, ET: 14.71, 60':2.50, MPH:97.87, TYRES:205/55/16, Optimax Extreme
People if you can post your times in this format
this way its only a cut and paste with a few number changes
nitrous or not
Nissans only
thanks Brett
No excuse about crap tyres or first outing etc. hahahaha
ET:10.364
MPH:133.9
60':1.493
Tyres:M/T ET Street radials
Nitrous:not
Race Fuel:C16AU
Nissan:R32 GTR
Link: http://www.fullboost.com.au/records.php?class=10
Edited by DiRTgarage
Um, I only have Time Slips form when I only just got the car (about 2hrs worth of driving) I suppose GTech times don't count.. But here is my best time for now.
R32 GTR
Bridgestone RE's
Ultimate 98
ET - 12.78 @ 110
60' 2.079
Slip link - Slip Here.
Movie of Run - Movie of Run
As mentioned before not the best, but I am getting flat 12's now on the Gtech in 35+ deg heat on crap NW WA roads *cough* I mean tracks.. Hoping to get some more times in the future once I get to a decent track, only 1600kms from the Plex at the moment.
Nissans only
Boo! How come I can't play? It's not like there's a BMW M Coupe forum with only 20 of them in Australia!
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
    • I was able to complete installation of the G4X ecu. I needed to reroute MAP vacuum signal from stock location to where BOV is connected on the intake plenum. Has anyone needed to do the same? When I connect vac port by the BOV flange to my HKS BOV, it doesnt work and I get flutter. I would to get BOV working, where would it be best to T in? Or would it best for me to move MAP vac line and T into FPR? Secondly, I installed a MAC 3 port boost solenoid and wanted to know if i routed it correctly. I place two lines from stock boost solenoid and placed it on ports 1 and 2, leaving 3 vented. The T for wastegate and boost source on compressor elbow is on port 2, and port 1 is connected to turbo inlet intake pipe. Please see attached pictures. Ill upload ecu config later today. Thanks in advance.
