Mysteries Misfire (r32 Gtr)
itbmils
OK guys
I surrender - I've had a VERY intermittent misfire in my R32 GTR for a while now - and I need some suggestions on what to look at next.
I have had a full engine rebuild, not to fix the misfire :D, but I did have it before the engine rebuild. Since then I have changed
ECU - now have a PFC installed and tuned
New iridium plugs
New splitfire coil packs
New SX fuel reg
New Fuel filter
New Tomei fuel pump
New Tomei timing belt
New pullies and tensioners
New Tomei Adj CAM gears
(New bloody everything)
The injectors have also been cleaned and flowed
I get the misfire once every 20-30 mins of driving - so not very often - but when it comes, it s big one. I get a big miss (feels like I've hit a pot hole) and I get a small back fire thu the engine (not the exhaust). It seems to be more dramatic when cold – but I still have the problem when hot. It can happen even under low load and/or full boost too.
No, my tuner does not know what it is either – but they are more than happy to charge me $70/hr (plus a shopping list of parts) to find it.
Could the igniter cause this, what about the coil pack wiring loom, battery, alternator (ARRRGGG!!) ?
If I get hold of someone with the PFC software – will that help to track things down. I could buy it myself, and run the car around attached to my laptop until I capture something ?
talk to me - this does not seem to impact performance - but it's FARKING annoying
What havent you changed then? If it is that intermittent, doesnt sound like wiring but still could be...
Does this happen when driving in a straight line, cornering?
OK - the things I have suggested are about the ONLY things I have not changed yet
battery
plug leads
igniter pack
alternator
is there anything else in the ignition chain that I have missed (I'm not a mechanic or auto electrician, so there must be) ?
It can happen any time - straight line usually now that I think of it - could a dodgy battery connection do this ?
I installed a 'grounding kit' a while back - and the -ve battery terminal is a little over sized for my battery - but still tightens up OK (I'm grasping at straws now !!!)
So - would the PFC software capture this sort of electrical fault ?
Is it just a single miss every so often that makes the car jump a bit or does it constantly miss for a few hundred rpm through the rev range?
If its just a single miss, you will be happy to know my car does it :D A friends car was fine as well, he put a power fc in and it also does the same thing now. As for what it is, no idea. I have had the car tuned by multiple places and no-one can get rid of it. Two of the places have also said its a problem in the specific revision software power fc I have and its not fixable.
If you find a solution, let us know :D
Yeah, i agree, try the leads first..
Also could try cleaning the plugs again, even though you have just changed them...
Where are the coils located? Are they like the standard coils on top of the plugs?
Yep – the splitfires are a direct swap for the old coil packs (which are obviously fine BTW)
where would I get new leads - I'm thinking of the words
Nissan and wounded bull - right :D
Can I get a set made up ?
could be an air flow meter loosing a signal for a split second, or the wiring plugs to them a bit dicky?? that could do it, have they been swapped??
Well my GTR has leads - not high tension leads tho - more of a loom really. They run from the igniter to the coil packs. Mine look old and perished – and I would like to replace both the loom and the igniter – but I bet it's cheaper to buy the HKS CDI (Twin Power) – which is about $600AU delivered from Nengun.
No - I have not changed the AFMs - yet
I do have a pair of Series II RB25 AFMs to fit up- but I need the bigger suction kit (and a full retune) to do that - they are on the list
I will check / clean the connections tho – and let you know
what the hell are leads? Correct me here, but dont oldschool cars with dizzys and coils have leads to link em up to spark plugs right?
Coil packs which are in skylines sit right ontop of the sparkplug with no intermediate lead connecting the two. Unless you mean the plugs?
the coil pack still needs to be connected to the ECU and a power source - right ?
so as I said - it's not a high tension 'lead' - but they do have a wiring loom that connects the coil to the rest of the ignition system
the coil packs take the place of a single shared coil in a typical car - which means the electric charge actually builds at the coil pack (stronger and faster than a single coil). But even a normal coil is connected to the battery somehow
trust me dude - I have leads that come off the coil packs
HtH
Hey,
if you have PFC and a dodgy AFM, you _might_ be lucky enough to see it on
the section that shows the sensor outputs. Have someone monitor the hand
controller, and see whether there is an AFM voltage out of whack (they should
be fairly similar, and I think always above 1V) when you have the miss.
Regards,
Saliya
your talking about the wiring loom then.....a simple check with a volt meter for continuity will be enough to decide...if its a closed circuit from one end of the wire to the other then there is no need to replace it.....igniter modules are a week point on that model.....i would be sniffing around that
Hey,
Regards,
Saliya
OK - didi some monitoring - and the AFM reading clearly takes a dip when I geta misfire - but does that mean it's the AFMs
I mean - if I've had a miss for some other reason - that would imapct air flow - right ?
Yep - I've done that - problem is - it's very intermittent
I'm not sure this type of test would actually capture a dead short - as it only seems to happen from time to time
the wires are very old (brittle) but they still seem to conduct OK to me. The plugs seem OK too (also old)
I'd like to replace the leads and the ignitor – but I'm not sure where to get them from
Hey,
Sorry, I don't think I've made myself clear :D Yes, when you have a miss, your airflow will
go down (I don't know exactly by how much, because my car doesn't do that). But I _did_
have a faulty AFM, the behaviour on-car was much like a very intermittent miss.
If the AFM is giving faulty readings for enough of the time to alert the PFC, the PFC will light
the exhaust temp light (disconnect an AFM and start the car, you'll see what I mean).
But my one would only read badly occasionally, looked like a dodgy contact inside
the AFM itself - not long enough to light the light but long enough to have the engine hesitate.
If it's a faulty AFM, that particular AFM might have a reading that's out of whack (with the other one).
Say one AFM is reading 2.5V, but the other one is reading 1.1V, check the lower voltage one.
Or if at any time either AFM reading is below 1V, that is abnormal. In my case, when I had
the fault the person monitoring the controller could see that the voltage of that particular
AFM went down to nearly 0V. But it would only do it for a fraction of a second - hence, why
you will need to be lucky :D
Regards,
Saliya
well i'm not an expert on mechanics or electrics, but i can only put in the following in hope that it might help
seeing as you have spent so much on an engine rebuild and obviously want it to run perfectly.. have you considered buying an entire new wiring loom and replacing your old, worn, broken wires with the new loom? who knows where you might have a broken wire that may be coming loose intermittently..
anyway good luck
Warren.
