Cleaning Air Pod
MM2death
  • Replies 50
depends what type of filter it is, mate. If it;s a K&N, you can buy a filter cleaning kit for about 25bux. Tells you how to clean it with the stuff included and gives you an aerosol of messy pink goop to re-oil it when your done.
If it's something else then i'm not sure. Only ever owned K&N's.
Someone will tell you though.
Adrian
benm
i did my hks pods (green element). They are buggered and need replacing anyways, so i thought i'd try a bit of a clean. Hot soapy water didnt do much, but get the degreaser on to them and wow! There is alotta black crap these things can hold. Left them to dry in a 29celcius night, put back in car and everything sounds a lot crisper. Im not sure if these are meant to be oiled or not????
u can use the k/N cleener kits to clean all the makes of filters. They are basically the same anyway, nt like they r made from different material! :P
Cleaned my a week ago.
Get K&N cleaner and oil.
Got a pack that had the two for about $29.
Tap and brush excess dirt off.
Soak with cleaner.
Let sit.
Rinse from inside out.
Allow to dry.........Over night.
Re-Oil.
Originally posted by MRK25T
How can I clean my Apexi air filter ? Is it the similar to Pawleys HKS pod?
Mark
Are you sure that's an Apexi? It looks more like a Blitz metal mesh one. The only Apexi one I know of is a high flowing paper element one, and with either that or the metal mesh style, they don't need to be oiled.
If yours isn't either of the above I can't answer your question :(
I don't think the apexi's need to be re-oiled as they are not a 'wet' filter, whereas the K&N is, thus it needs to be re-oiled.
The HKS filters are not meant to be washed, but replaced altogether.
Apexi Filter
Jimmy, thats what they described/named the filter at the dealership I bought the car from. I haven't had a good look at it to see if it had any brand name so your probably right.
It is a metal mesh, so should I pull it apart and clean it like mentioned above and not worry about oil?
Mark
