Rb25 Turbo Onto Rb20
bj_dove
gday everyone, as the topic states, im just wondering how easy is the change from the stock rb20 turbo to the r33 unit? as far as oil/water lines, etc. go?
(btw, did a search but couldnt find anything, sorry if its been covered b4!)
Ive done the swap aswell and you will find a god increase in power for the same boost.
If your not using a bc make sure you swap over the Actautors as the Rb25 one is set around 5psi from memory and the RB20 is set at 10 psi i think.
As jas/slo32 said its quite easy to do.
Does the RB20DET's compressor elbow that connects to the IC piping bolt up to the R33 RB25DET turbo?
I know the R34 Compressor covers outlet is slightly larger than the RB20DET's. As a result you have to use the R34's elbow.
Has any one taken to time to measure the Comp wheel of an rb25 turbo?
I have a few approx measurements..
R34 RB25 Turbo.
Inducer - 49mm
Exducer - 66mm
Approx Trim - 55
VG30DET Turbo
Inducer - 46mm
Exducer - 63mm
Approx Trim - 54
The R34 RB25 and VG30 turbo's share the same slightly larger turbine housing. Apparently it measures some where around the .7 a/r where as the rb20/25 is around the .6 a/r. I was told the sizes by a turbo shop.
When I pull my rb20det turbo off I will measure its wheels and also compare.
Edited by Cubes
R34 RB25 Turbo.
Inducer - 49mm
Exducer - 66mm
Approx Trim - 55
VG30DET Turbo
Inducer - 46mm
Exducer - 63mm
Approx Trim - 54
yeh you need the rb25 turbo elbow. rb20 doesnt fit
no.. tried it.. bolts holes don't match up that well, and smaller diameter hole on the flange. You sort of *could* get it to work via redrilling, but could cause problems.
all i can say on that is.. good luck!
I don't know why people always take them off when they sell them as they can't be too useful for anything else, but you tend to find a large number of the rb25 turbos without them, and they can be a bitch to track down. ;)
No probs. I'll pull the comp cover off and take some more.. It appears I've misplaced the ones I took prior. :D
R34 cover is the same size as the VG30.
RB20 is smaller yes.
Edited by Cubes
    • Thanks - to be sure will the WHC34 work?  I can’t find the other one anywhere.  Thanks
