How To: Stagea Headunit/stereo Removal
AlexCim
Thanks to STAGE-A for the wiring
12V ------- Brown with white stripe
Ignition -------- light blue with yellow stripe
Lights -------- Red with blue stripe
Earth -------- Just use the stereo metal brackets
and heres the speaker connection wires (stagea s1 at least)
left front ---- blue (+) black with white stripe (-)
right front ---- brown (+) black with red stripe (-)
left rear ----- mint green (+) black with yellow stripe (-)
right rear ---- orange (+) black with pink stripe (-)
Useful tip guys and girls:
Always use a circuit tester as opposed to a test light, and always be very careful when doing so!
Test lights, when used incorrectly, have been known to trigger air-bags, leading to a hell of a lot of wasted cash and a big clean-up, not to mention any personal injury that may occur when a bag goes off while you're in such close proximity to the dash and/or the steering wheel.
The force and speed at which an air-bag inflates is not something you'd really want to experience first hand.
Tip if your hookin up a DVD playa as i did and want to be able to play when your driving (not just when you have the foot brake on) simply connect the hand brake wire from the deck with the earth wire from the deck and earth them both together. simple!! WARNING technically this is illegal and im not advising you to do this if your screen is in the front.
So lets get started ripping that sucker out!
Pull out the ash tray and remove the screw from behind it
Remove all your stuff from your centre console.
Stick in the screw driver here. You can also pull from the indent thing where you put things, pull up. Make sure the car is not in park, otherwise it wont come out. I just put it in N or something
Now that your console is off, unplug the ciggie lighter plugs from the back of it
Edited by AlexCim
Move the console off to the side, no need to unplug anything. I have extra stuff down there (hi/low boost switch)
If you have two hands, i didnt (camera) put the screw driver in the two locations. Put them pretty deep so that they get behind the vent.
The vent will just pop off once you have done that
Remove the screws that hold the stereo surround on. Also there are some clips. On my car, they were really loose and easy to pop off
It will just slide off now.
There are screws under the above the frame of the units. Make sure you remove the lower ones first. be careful not to drop any. If you do, when you remove the whole unit you will be able to grab them. Once the screws are out, the unit will drop a bit. Its fine, dont get scared.
The unit will now just drop off.
Pull it out and do what is desired
Screws for the stuff are on the side. When you remove things there are also "indents" that hold the units in. You MAY need to flex the frame a little to pull anything out (i was like wtf when i had to remove my DIN slot)
To reinstall, follow the reverse. All the screws are the same, so dont worry about mixing them up.
Good luck. I cant offer wrie diagrams as i didnt install the headunit myself, maybe someone else can post them here and ill update the post.
See the 4 way (hazard) flasher switch, top right of the picture. if you flick that out you can get your finger behind the vent and push it out, doesn't leave marks like the screwdriver can.
;) cheers :)
Do l seriously have to do all that to put an fm convertor thingy in so l can listen to australian FM stations?
if so damn.......l think l better start backing up some of my cd's, or add more songs to my Iriver.
Edited by NRGIZD
  • 3 months later...
Hey Guys,
Sorry to post here, but I'm having a bit of trouble getting the rear speakers out...Cant remove the mesh cover thingy, any suggestions? Need some help pretty quick guys. I know it has clips on it, I have already broken 2! Any help would be appreciated.
Cheers,
Chris
i've completely rewired and reinstalled all speakers/splits/tweaters and also installed a sub box in the boot, so i know how the stagea pulls apart. if anyone needs help give me a buzz
x2 here!!
even know how to get 0 guage wiring through the firewall!!
Back speaker set up is awesome ... fronts were a pain as hoped not to have to make a custom pod behind the skin, but either way came up looking good (and still stock!! )
k im just installing my head unit so i'll post up the wires from the wiring harness as i go .. so far
Id advise still using a circuit tester just to ensure yours are the same as mine before you hook up your head unit, if unsure how to check just pm me.
Tip ..With these ones always use female connectors, incase the connection becomes loose the "hot" wire will always be insulated.
Ive installed my boost guage at the same time making it easy to use the same connections.
I'll post up the speaker connections as i do em ... unless anyone knows em and can post em up an save me some time too :D
Lee
k heres the speaker connection wires (stagea s1 at least)
Lee
Edited by STAGE-A
Cheers,
Nick T.
    • Hi all, I need to get this HKS SLD attached to my stock ECU because I've now got the German autobahn and faster European circuits to contend with.  The car is a manual 2dr ER34 with an AT ECU and I've realised the AT ECU has two pins for speed sensor signals: Pin 29: Vehicle speed sensor signal (Vehicle speed sensor 2) Pin *58: Output shaft rotation sensor signal (Vehicle speed sensor 1) - *RB25DET A/T model only Before I go butchering this harness, is anyone sure of which pin is the correct one for signal adjustment? The attached document from HKS indicates pin 29 but I found this situation mentioned in the following thread on a different forum (R34 GTT Auto Trans Speed Cut Problem | Zerotohundred) mentioning pin 58 needing to be altered by member zephuros, albeit it seems to be for an RSM-GP and the info appears to be old.  R34_All_Workshop_Manual-pages-2.pdf R34_All_Workshop_Manual-pages-3.pdf R34_All_Workshop_Manual-pages-1.pdf HKS SLD Vehicle Pin out P59-P70 ER34-pages.pdf
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
