Skyline Manuals - Download Available
Links
Update
Due to being contacted by JPNZ - I have removed the R32 and R33 manuals from the site as per their request.
Please do not contact me for them.
Thanks
http://www.crankroom.com/sau
username: sau
password: august
AVC-R_manual.pdf
BLITZ/
HKS/
Nissan Self Diagnosi..>
Skyline - General In..>
TurboSmart/
book.pdf
cold air induction/
convert2.xls
r33-fusebox-1.txt
spark plugs diagnosi..>
If you have any questions - feel free to contact me via email or pm.
Thanks,
Links
Edited by Links
  • Replies 105
Good to see you gettin into the spirit of things Links :)
Where are the a31 manuals though? O_o
Waiting for someone like you to jump in and upload them mate :)..
if you have any stuff - put it up..
good luck on sun - personally won't be able to make it (grrr.. don't ask - had something already aranged)..
Anton - not quite sure what you mean by "i can't get it to work", are you referring to the site or the PDF??...
Dont' have the R32 gtst manual yet - if someone could upload it - that'd be great, not sure what the R32 all engine service manual has in it, that might help..
Justin - yeah - I know - however they have been around on other sites for ages, if they complain - well.. they complain - site won't be indexed by google - and of course, no one on here is going to go around giving out the username and password are they :thumbsup: are you now ppl..
Enjoy.. remember - if you have anything else and wanna put it up - go for it.. while there is still space, you can still use it..
